1992 eg hatch battery problem
so i got a new battery today and new terminals, i want to redo the wiring coming from the starter and the ground,so i took the old battery out undid the the wire coming off the starter and same for the ground but now when i plug the positive cable coming from the start there is tons of sparks,any answers please help i need my car running again and soon thanks.
i tryed to hook up the old wiring and did the same thing
Re: 1992 eg hatch battery problem
You could just Bump your Original Post instead of making another one. But anyways, have you checked your Main Relay? Usually the case when nothing happens after you turn the key but since the radio and stuff comes on idk about that. But i'd check the Main Relay first thing.
No problem man just remember to search before you post and you'll be good. Let me know if thats the culprit. I'm sure you can find a thread about how to check your main relay. Check of the FAQ's Thread on here.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
I Just did
Here's the Location
http://i639.photobucket.com/albums/u...cture_3675.jpg
And here's how to test it
http://i639.photobucket.com/albums/u...cture_5581.jpg
There's a lot of good stuff in there. Be sure to check there to before you post too. You'll find a lot of your answers there.
I Just did
Here's the Location
when i plug the positive terminal in there are tons of sparks,
when i go to turn the key nothing happens,no light no radio nothing like there is no battery if i go and unplug the starter lights go on and radio ,i replaced the main relay today still nothing.
i think i hook it up right one ground going to the battery wire coming from the fuse box to positive and the wire coming off the start to positive am i missing something?
Did you do a one for one swap with the wires ( meaning as you were pulling it apart putting the new wires on) or did you take it all apart then put it back together by memory? To me it sounds like you didnt put it back together correctly
lrcrx90
12-16-2006 07:48 AM
FindingEmo
08-05-2004 06:46 AM
