12v cigg socket help
Old 11-13-2004, 02:08 PM
SpoonIntegra808
Guest
Posts: n/a
Default 12v cigg socket help
Help, my 12v auto socket aint working! I checked gthe fuse and replaced it! same results it doesnt work!! i wanna add my radar das why!
any idea what could be wrong>? how much to fix?
Old 11-13-2004, 02:48 PM
miahmouse's Avatar
Default Re: 12v cigg socket help (SpoonIntegra808)
check the fuse inside the radar detector plug or plug something else in you know works.
if it still doesn't work, make sure it's plugged in behind the dash and check for power at the connector.
if no power at plug then check fuse at fuse panel again then trace wires.
still doesn't work, and you haven't a clue why then take it to an audio shop...
Old 11-13-2004, 05:46 PM
tuphatt's Avatar
does your radio work?
i think the radio and cig adapter share the same fuse
I believe there is a fuse box under the hood by the battery that has a fuse for the cig. adapter.... it will give a diagram on the cover box
Modified by tuphatt at 9:11 PM 11/13/2004
Old 11-13-2004, 05:51 PM
CooBlueDAB's Avatar
Default Re: 12v cigg socket help (tuphatt)
from taking the dash apart many times, I can say that miahmouse had the right idea with the wire coming loose behind it.. its not on there tooo tight, and worth checking.
burntfuze
Honda Civic (2006 - 2015)
02-13-2013 06:28 PM
matmcg
06-20-2007 11:42 AM
AcInTheEg
Audio / Security / Video
05-02-2007 04:05 AM
kturner2007
12
01-09-2007 10:03 AM
crx_kid
10-15-2003 11:08 PM
Quick Reply: 12v cigg socket help
