1/4 mi times for stock and modded Del Sol SI
I have a 1995 Del Sol SI with a t25 running 5psi.. I haven't run the 1/4 mile yet because I have been working a lot.. I just want to see what these things run stock and modded.. Don't expect to get a really good Idea of what mine will run, just want to see what everyone else is pulling.
Re: 1/4 mi times for stock and modded Del Sol SI (90civichb)
hey, how's it goin? I believe the stock 95 Del Sol SI has a time of 16.6sec at 84.6 mph in the 1/4 mile. I am not to sure about your modded Del Sol. How much did you get that turbo for?
Re: 1/4 mi times for stock and modded Del Sol SI (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">REALLY SLOW! you wont like it, so just give me your turbo kit </TD></TR></TABLE>
yea good thinking
yea good thinking
http://www.teamdelsol.com the answer for stock can be found here... not sure about modded. Have you tuned the setup? What else is done to the car? There are a few other factors to consider beyond the snail in there . Good luck at the track for keeping it off the streets
Re: 1/4 mi times for stock and modded Del Sol SI (FrostySol)
Nothing to tune on my setup at the moment.. the only things actually installed are fmu, turbo, fuel pump, BOV, gauges, and black box.. its set at 5 psi.. Once I have the injectors, fmic, ignition, etc. installed I will look in to getting it tuned properly.
Ditch the FMU and use the VAFC along with DSM 450cc injectors for fuel management.
Some of the guys off HMT are getting pretty good HP running 7-8psi on stock d16's. I would not be surprise if you got mid-high 14's with that setup. But before you go to the track... tune it!
Re: (B16Drag)
Not a whole lot of tuning you can do with the afc hack... that will only be a temporary deal.. not sure what I will get later, just know that I want something more tuneable.
locote
07-28-2006 12:37 PM
