00 honda civic ls swap, fuel pump wont prime, brand new relay
Old 08-07-2017, 08:15 PM
Nitrozity74's Avatar
Default 00 honda civic ls swap, fuel pump wont prime, brand new relay
Hi, i did a ls swap in my 2000 honda civic, got everything hooked up fine ready to crank and the first time i tried starting it I didnt hear the fuel pump prime. Therefore i put a multimeter on the main relay connections and all made 12v EXCEPT #7. (fuel pump) This is also with a brand new relay. I already wired a live wire from battery to #7 and it primed so i know the pump is good. Any ideas that might be able to help?
When i turn the ignition switch off, i can hear the relay click.
Old 08-08-2017, 06:05 AM
mk378's Avatar
Default Re: 00 honda civic ls swap, fuel pump wont prime, brand new relay
Check the ECU grounds. When you turn key on and don't crank, does the check engine light come on then go out?
Old 08-08-2017, 08:14 AM
Fish Twig
tony_2018's Avatar
google 'swaps into 2000 obd2b civics'
look up verify your ecu wiring is correct
Old 08-08-2017, 06:10 PM
No lights come on the dash except my battery light. Battery is charged and getting 12 volts. I am going to double check my grounds again tonight but im almost positive all grounds were good.
Old 08-09-2017, 07:04 PM
Bump, still no luck.
Old 08-09-2017, 08:48 PM
dgdarien's Avatar
My fuel pump wouldn't prime recently either; the ECU was dead.
Old 08-10-2017, 05:26 AM
mk378's Avatar
Turning the key on but not starting, the oil pressure light should also come on. That light is on the same circuit that supplies the ECU and the ignition.
Old 08-10-2017, 06:25 PM
Technical Hero
HondaPartsHero's Avatar
What ECU and how did you wire everything
Old 08-10-2017, 08:34 PM
Usong a chipped p28 ecu. Like i said absolutely no lights on the dash other than brake and battery
Old 08-11-2017, 03:03 PM
Fish Twig
tony_2018's Avatar
Old 08-12-2017, 06:05 PM
Wire everything for what? The ecu is hooked up by a jumper harness
Old 08-12-2017, 06:36 PM
Seagull Management
94EG8's Avatar
You may have to move pin A16 to A15 on the engine harness.
Old 08-17-2017, 08:36 PM
Update- Found out my ground to thermostat was bad, fixed that and it gets good ground now. the only difference is i can crank my motor now but the fuel pump still wont prime! No CEL, only lights on dash are brake and battery. Main relay is brand new, fuel pump is good. Still no solution can somebody please help
Old 08-18-2017, 08:02 AM
Fish Twig
tony_2018's Avatar
dude if you can't read what has been stated just take it to a shop.
Old 08-19-2017, 09:04 PM
Seagull Management
94EG8's Avatar
The thermostat ground is the ECU ground.
Old 08-21-2017, 12:18 PM
Heres a picture of my ecu hooked to jumper harness. Car cranks fine fuel pump wont prime still.
Old 08-21-2017, 12:21 PM
I also found this after taking my cover off, seems like the previous owner really messed with something here. Does anybody know exactly what this plug is for?
Old 08-21-2017, 12:54 PM
mk378's Avatar
Hi, i did a ls swap in my 2000 honda civic...
Does this mean that the car was running OK with the stock D series motor and OBDIIb ECU when you first got it?
Old 08-21-2017, 08:10 PM
The car is a 2000 si, i bought it as a shell
Old 08-22-2017, 07:50 PM
Bump.. anybody
Old 08-22-2017, 09:11 PM
JRCivic1's Avatar
I suggest you ignore the wiring at the column at this point and focus on the MESS you have over at the ECU. Your pic above shows FIVE ECU plugs... one laying in free air and another four plugged into your adapter harness meeting three on the other side. Does this not cause concern/pause for you ??? How about posting closer/clear pics of those plugs as well as the crossover plug (the green one) to see which wires do not correspond to something on the other side. My suspicion is you do not have a matching engine/dash/chassis harness group.
chandler58
23
03-28-2013 12:22 PM
radicaled434
10
04-27-2012 04:10 PM
ls_vtec_da
05-07-2011 09:05 PM
1993-eg1
01-28-2009 11:17 AM
Soccerking3000
12
12-21-2005 06:10 PM
Quick Reply: 00 honda civic ls swap, fuel pump wont prime, brand new relay
