00 EX passenger window will not go down
Old 06-26-2009, 07:27 AM
red civic standard's Avatar
Default 00 EX passenger window will not go down
I thought it was the power window motor, so I took of the door panel and hooked the motor directly to the battery and it worked....so it is not the power window motor.
Then I thought it was the switch on the passenger side, so I replaced it with a known working one and the window would not go up....so it is not the passenger switch.
Then I thought it was the switch on the drivers side, so I replaced it with a known working one and the window would not go up....so it is not the drivers switch.
All the fuses are good.
Any other ideas?
Old 06-26-2009, 07:41 AM
Former User's Avatar
Default Re: 00 EX passenger window will not go down
No offense intended, but might the main switch be turned off?
Is it a sedan or coupe?
Use your multimeter to check for an open in the GRN/BLK, BLU/ORN, BLU/YEL, BLU/RED, or BLU/WHT wire.
Pauly321
12-02-2016 12:15 PM
brent_si
Honda Civic (2006 - 2015)
09-18-2014 09:11 AM
lucfleclerc
04-25-2013 01:55 PM
hondapwr
07-17-2009 05:30 PM
madlion
01-20-2005 06:56 PM
Quick Reply: 00 EX passenger window will not go down
