NUMBER OF HONDA QUESTIONS *HELP*
OK here's the deal recently swap in a complete jdm b16sir2 into my eg hatch for a daily driver . the problem im having once i installed the motor i noticed a number of small problems , 1. would be the driver side mount needed to be replaced , (i know that the only U.S. motor that is capable with the sir2 motor is out of the 94-97 delsol b16a3) and 2. is that i do not have the 2 top a/c lines to run to the compessor .
now my questions are for the motor mount which one do i use ? the delsol or is there another U.S. b-series mount that i can use ?
and which a/c lines that i would have to use on that compressor ?
Re: NUMBER OF HONDA QUESTIONS *HELP*
Have you ran a search for sir2 motor mounts in the forum?
I don't know which mounts to use but I'm sure I saw someone post this a few weeks ago. Something is telling to use the teg LS mounts but I could be wrong.
I know innovative and hasport make them if you wanna go aftermarket.
yea i ran a search but nothing really useful showed up , and it sounds like to me that i might have to be going aftermarket
You just need a driver's side B-series mount, I'm not sure if the '99-'00 Civic Si one would work though. But one from a Del Sol or from an Integra will work. You also need the rear mount bracket from a B-series (Del Sol or Integra again).
For the A/C, you use your stock Civic compressor, with a Del Sol VTEC (with one with the B16A3) compressor bracket.
ok i was told the easiest way to fix my a/c problem would be to , use a single cam compressor with a delsol bracket and stock 92-95 a/c lines .... can any one chime in on this ?
^ That's exactly what I said you should do. The stock D-series compressor will bolt right to the del sol bracket, and the lines will obviously work, because they are the lines meant for the compressor.
RTCdominicano
01-23-2006 10:38 AM
