00 Civic timing belt probs.
yeah i've tried searching for my prob. no help tho. i hope this is a relevant forum to put it in. oh well here it is:
so when i go to start my car i hear the timing belt make noise as it goes round and round. i thought i needed a valve adjustment but that wasn't it. its def. the belt. so its only when i start it. i'll hear it make noise all the way down my driveway as i reverse out. then when i go to a higher gear it goes away. then at stoplights/signs it doesn't make noise anymore. just when i start it and back out.
how can i go about and solve my prob? any suggestions?
thanks guys!!!
thanks guys!!!
Re: 00 Civic timing belt probs. (nasirjones9mm)
yeah, a timing belt is going to be a whine sound...that is if it's too tight. but being a 00 model you probly still have the factory belt on there so it's not too tight. check the tension on your outer belts.
Solbros Owns Me
Re: 00 Civic timing belt probs. (hondamark35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamark35 »</TD></TR><TR><TD CLASS="quote">yeah, a timing belt is going to be a whine sound...that is if it's too tight. but being a 00 model you probly still have the factory belt on there so it's not too tight. check the tension on your outer belts.</TD></TR></TABLE>
BOOSTEDgreeneg
05-25-2005 12:51 AM
cr00klyn718
09-05-2003 12:53 PM
