00 Civic - overheating
I have a 2000 Civic DX that overheated and melted a hole in the overflow reservoir cap. I have not noticed white smoke and no bubbling with radiator cap off. Is this even worth repairing?
Re: 00 Civic - overheating
As the coolant entered the reservoir it melted a hole in the cap. When I figure out how, I will post a pic? Dealership said the radiator is corroded and the thermostat was not operating and caused the issue. The vehicle has 153k miles.
She takes it to the dealership for regular maintenance. Not sure when or if a coolant system flush was done. I guess I have to be more diligent in teaching them how to care for their vehicles, sorry if I ruined your day Marc.
Yes, its worth fixing provided the vehicle doesn't have all sorts of other problems.
even if you have a shop do the work it'l be cheaper than replacing a 6th Gen civic
The Grumpiest
Bullshit. All this time and the dealer never changed out the thermostat or noticed the radiator was "corroded"?
Still waiting for you to post the pic and stop trolling.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/rules-thread-titles-car-information-searching-trial-users-picture-posting-3002401/
Yeah...I'm skeptical about the overflow cap melting. Its purpose is to accept exceptionally hot coolant boiling over from the radiator. It "catches" this boiling fluid.
Unless the composition of the fluid was incorrect...if it has a chemical that raised the boiling point higher than it was supposed to be.
The Grumpiest
This is the same troll that starts new identities and posts up situations that are pretty impossible to actually have happen as tech questions. Remember the one where the evap cannister would overflow with coolant when he attempted to add some to the radiator. Same M.O. Claims he'll get a pic posted and never comes back. Probably some knucklehead from GDD.
Took awhile for me to figure out, but here are some photos
They can be viewed here.
https://honda-tech.com/album.php?albumid=42297
Hope this works
Hope this works
The Grumpiest
Sorry. Don't believe the coolant did that. They reason I have a problem believing you is because the whole reservoir is made of the same hi-temp plastic as the cap with the same thickness. So, the damage should have been worse than that IMO. Shouldn't the cap have been deformed with not just a hole in it? That's what usually happens when you start to melt plastic. And all things being equal shouldn't have the bottom of the res melted before the top? It looks like someone held a cigarette lighter to that spot.
I'll have to go with my man shotoutacc0rd for once.
Maybe from the heat and pressure from the coolant entering, that's all I can figure. Replacing all the components, hope it works.
Thanks for all your input, ...no really, I ENJOYED IT. Hope your meds kick in soon, Have a Nice Day
The Grumpiest
Now if this is some rare freak occurrence, then so be it but having to even ask if you should replace defective components is pretty much a no-brainer I would think. But I still think you're trying to punk us. The lengths some people go to.
Poor Marc, It is what it is, I have no hose in the reservoir that I saw. I will take photos of it or whatever else you need to see. Its not a hoax bud, stone cold fact my Man.
