[FAQ] What parts are interchangeable for all 92-00 Civics?
#326
Re: [FAQ] What parts are interchangeable for all 92-00 Civics?
Even if it did why would you want to? I think they even appear different. *mirrors
The Del Sol doors are much heavier than civic doors. They're reinforced because of the target top. You shouldn't have a problem finding civic doors, the wreakers out here always have a healthy amout of civics.
#327
What years and models rear backing plates are interchangeable for a 94 civic ? I'm checking out some parts cars currently and want to make sure I find the right parts that fit.
#328
"Integras 94-01 share that same identical rotor size, and caliper bracket - which means Integra front calipers bolt directly onto the civic ex/si knuckle."
Does this also mean that the integra calipers would bolt directly to a 93 Del Sol Si knuckle? From what ive read it seems i may need an integra/civic knuckle.
The civic si and delsol si have different size front brakes because of the civics ABS. As where the Sol vtec came stock with the larger front brakes similar to the civic SI. Which contradicts the thread. Any help / updated list would be much appreciated.
::My brake upgrade notes::
FRONT ------------ Integras 94-01 front calipers
Integras 94-01 share that same identical rotor size, and caliper bracket - which means Integra front calipers bolt directly onto the civic ex/si knuckle. The pistons are noticeably larger.
all Integras share the same size brakes.....minus itr. Dont get suckered into paying more for them, if the LS brakes are cheaper
92-00 civics, and eg si hatches will need an ex, em1, or integra front knuckles to bolt the larger brakes on
REAR------------- 96-00 DelSol Vtec ----------- Integra 94-00
But whats best?
Brake calipers and brackets (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
Rear trailing arm with hub assembly for disk brakes (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
OK
PROP VALVE
Civic EX 15/16th non abs MC
OK
Parking brake cables (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00)
OK
EH Caliper Piston Size:
Del Sol Si/S < Del Sel Vtec
Del Sol Vtec = Civic EX/Si
EH Rotor Size:
Del Sol Si/S - 9"
Del Sel Vtec - 10"
DC Rotor Size:
Integra GS/RS/GSR - 10"
But whats best?
OK
PROP VALVE
OK
OK
EH Rotor Size:
Del Sol Si/S - 9"
Del Sel Vtec - 10"
DC Rotor Size:
#331
I'm new to the forum and not a Honda expert. So I apologize if I don't have all the information needed to answer my question, but I'm wondering if the headliner and windshield from a 95 civic sedan will fit in a 97 sedan. Any help would be greatly appreciated. Thanks.
#332
Honda Parts at Honda Parts Now | Genuine OEM Honda Auto Parts
Majestic Honda - The Internet's #1 Honda Automotive Parts Store
etc.
#335
talks to himself
Bump for FAQ addition or sticky addition or at least to get it to the front page since people have been asking interchangeability questions.
#336
Stuck for now until it can be added to monster FAQ
#337
im still new to this but for the last week ive been trying to find out what parts i can swap from a 00 civic lx to my 95 civic ex. so far according to auto zone i can interchange the fuel filter and a/c compresser
#338
I am also interested in this. I have a 95 civic EX non abs with bigger rear cast iron drum brakes. I want the smaller lighter aluminum rear drums from the 2000 honda insight, but my rear drum backing plate is too big so i need a smaller one from like a CX or perhaps any civic with a manual transmission and rear drum brakes, non abs?? The backing plate/backplate part is discontinued, so would the Rear Drum backplate from a 2000 honda insight work? or a backplate from an integra or delsol or something??? thanks.
#339
Don't know about the rest of you guys, but I have personally seen someone take a whole EG out from between its wheels and stick an EK back in its place. Same goes for an Integra (except the ITR with its 5 lugs).
#340
talks to himself
I probably just need a seal but, just in case, I want to be prepared to start scavenging parts cars.
#341
I obtained the drum backplate off of a civic cx and it fits the insight drums, but the smaller backplates don't fit on my civic ex so i got the whole trailing arm but the car won't move with the insight drums on so i got 5mm spacers for between the drum and hub, had to widen the center of the spacer a mm or 2.
Now it seems to be ok. Need to adjust brakes and e brake.
#342
Just gonna be short and sweet. Vehicle: 92 EG8 DX
Motor: D16Z6 swapping in JDM D15B bottom end.
DX harness. Do I need the EX/Si harness for this motor to run? Some say I might, Some say no. You're all the smartest with this and the FAQs offered no help. Thank you.
#344
Can JDM D15B bottom end with the z6 head take the place of a D16Z6 bottom end and be hooked up to the s20 b000 man. tranny?
#345
Just had a question, I got a leaky gas tank on my 99 DX Hatchback. Would I be save to say I could get a gas tank from a sedan or coupe between 92’-99’?
#346
So I have a 2000 Honda civic with a d16y8 and d16y8 automatic intake manifold and throttle body (vtec) running on a 2000 LX auto ecu, meaning that the sensor is on the throttle body. I just recently did my auto to manual swap and wanted to put in my P2P-a92 (2000 civic ex 5 speed vtec ecu) in but when I plugged in and turned the key it went limp mode. so we ran the auto ecu for now. what would be the best fix?? some say to drill the holes for a 2 wire sensor on manifold and block off the holes at the end. help very confused and tired of seeing y7 to y8 info.
#347
Any Interior and exterior body trim and paneling pieces interchangeable for a 92 civic hatch CX besides the civic coupe?
#348
Just getting into the Honda scene want to put a B18 into my 98 civic. What parts out of my automatic D series need to be changed to match the new motor and tranny plz and ty
#349
#350
Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (_RevHardD15)
92-95 hatchback and coupe hoods are interchangeable.
92-95 hatchback and coupe hoods are not in interchangle with sedans.
96-98 hatchback, coupes, and four door hoods are interchangeable.
99-00 hatchback, coups and four door hoods are interchangeable.
96-98 and 99-00 civic hatchback, coupe, and sedans frontends are different. Either all 96-98 or all 99-00.
