[FAQ] What parts are interchangeable for all 92-00 Civics?
Okay, I've noticed that there have been many "is this part interchangeable with this part on this car" types of threads lately. And frankly, I'm tired of it. Plus EVERYONE would like to know what parts they can use from other models or chassis. Integra parts can be included as well. ie. Seats, brakes
I would like to keep this thread clean and simple. <FONT SIZE="4">NO</FONT> "great thread" or "awesome write-up" kind of stuff. If you have information to add to this thread, post it up and THEN compliment on my post. https://honda-tech.com/forums/images/smilies/emwink.gif https://honda-tech.com/forums/images...s/emsmilep.gif The way I would like the information to be posted is: State what year and model civic the part came from. What the part is. And whether it requires and modification/fabrication to fit/work. <FONT COLOR="red"><FONT SIZE="5">The most important thing is that it requires no or VERY little modification/fabrication to work.</FONT></FONT> Alright I'll start it off. All of these rear disks will work on the 92-00 Civics. -First off, the 5 lug ITR setup. We all know this works. -Then there is the JDM 4x114.3 setup off of the ITR before it came to the states. -All of the Integra rear disks are the same for the 3rd gen, so any of the 3rd gen (DC) brakes will work. -Also, the 99-00 Si rear brakes will work. I believe that these are the same as the rear Integra disks as well. -Rear trailing arm with hub assembly for disk brakes (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00) -Upper control arm (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00) -Compensator arms at the front end of the trailing arm (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00) -Rotors (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00) -Brake calipers and brackets (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00) -Brake pads with shims (get the genuine honda ones) (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00) -Parking brake cables (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00) -Brake Booster (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00) -Master cylinder (92-95 EX/SI, 96-00 DelSol Vtec, 96-00 EX, 99-00 Si, Integra 94-00, 91 civic ex) -Proportional valve Rear trailing arms off the following will fit/work -All integra 90-01 -All civic 92-00 -All del sol 93-97 All these parts are identical (minus the hub). -All 96-98 Civic 2dr/3dr model upper grills (no modification) -99-00 Civic 2dr/3dr front ends on to 96-98 civics (corners of bumper must be cut to make it fit) -Every shift knob -99-00 Si Gauge cluster to ALL 96-00 civics (plug and play) -99-00 Si Steering wheel to all other 96-00 civics (bolt on) If you have pictures from when you did one of these swaps, by all means, add them. Thank you to pdiggitydogg, Ricey McRicerton, Luserkid, and perlmeistere81 for their information on all of the brake and suspension information. If any of my information is incorrect please tell me in a <FONT COLOR="red"><FONT SIZE="2">PM</FONT></FONT> Please, add on and make this a useful thread for everyone. https://honda-tech.com/forums/images/smilies/emthup.gif Modified by DOHC4life at 11:51 PM 10/15/2004 Modified by DOHC4life at 11:54 PM 10/15/2004 Modified by SOHC4life 96 at 9:30 PM 11/12/2005 |
Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (DOHC4life)
Not bad, not bad at all. Just needs pics https://honda-tech.com/forums/images/smilies/emwink.gif
As for front calipers:
Civic 92-00 EX and 99-00 Si (em1) share the same size caliper (including piston size), knuckle, and rotor. Integras 94-01 share that same identical rotor size, and caliper bracket - which means Integra front calipers bolt directly onto the civic ex/si knuckle. The pistons are noticeably larger. The Civic ABS setup is IDENTICAL to that of the Integra. (Integra GSR's do NOT have larger brakes - all Integras share the same size brakes.....minus itr. Dont get suckered into paying more for them, if the LS brakes are cheaper, where you are.) The rest of the 92-00 civics, and eg si hatches will need an ex, em1, or integra front knuckles to bolt the larger brakes on, as the brackets are smaller in size. (NOTE: You do NOT need abs to use the Integra/Civic ABS calipers! Abs doesnt work that way.) |
Re: (pdiggitydogg)
I was just asked this and felt stupid that I forgot to include it.
All 92-95 clusters are plug and play into any model 92-95 civic All 96-00 clusters are plug and play into any model 96-00 civic Also, I could be wrong on this one (correct me if I am please) but All D series intake and exhaust manifolds are interchangeable Come on people I know there's a lot more stuff that works. I want to see stuff about interior pieces. Like ITR seats in a ek, and how to modify them to fit. Keep this thread alive and useful. Edit: Removed "all B series intake and exhaust manifolds are interchangeable" Modified by DOHC4life at 11:35 AM 10/20/2004 Modified by DOHC4life at 11:35 AM 10/20/2004 Modified by DOHC4life at 2:26 PM 10/20/2004 |
Re: (DOHC4life)
your right, all the d series ex mani's are the same.
the radiators are the same [del sol is the best one though cause its dual core] |
Re: (eK9aT10pSi)
d16z6 water pump, tensioner, rear crack seals, oil pump, and etc will fit on d15b7's and d16a6. BUT NOT d16y8!!! bottom end on d16z6, d15b7 and d16a6 i know look almost exactly they same, same casting and such. The d16y8 and mostly d16y7 is different casting. HOWEVER the cracks are different, the oil ports on the crack in the Y8's and gridle, are bigger. YET all d16 cracks are interchagable.
To sum it up: D16z6/d16y8 real crack seals, water pump, tensioner, ac bracket, oil pump are not interchangable. The metal hose that water is pumped through behind the block are interchanbleable only. D16a6 (i know its not from 92-00), D15b7, d16z6 real crack seal, water pump, tensioner, ac bracket are interchangable. Basicly you can swap everything mounted on the block over back and forth. Modified by Br1anPham at 10:51 AM 10/24/2004 |
Re: (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi »</TD></TR><TR><TD CLASS="quote">your right, all the d series ex mani's are the same.
the radiators are the same [del sol is the best one though cause its dual core]</TD></TR></TABLE> not the same, but interchangable. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life »</TD></TR><TR><TD CLASS="quote"> All B series intake and exhaust manifolds are interchangeable </TD></TR></TABLE> I doubt it. GSR intake manfold studs location is different from b16/b18c5. i know this for sure. |
Re: (Br1anPham)
D16y8 and D16z6 Timing belts are interchangable. Even if they state different part numbers! ( The z6 belts tend to be cheaper )
D16y7, D16y8, D16z6, D15z1 valve covers are interchangable. ALL B series and D series throttle bodies are interchangable. (always use the gasket from the TB) D16y7 and D16y8 oil pans are NOT interchangable. y7 is baffled and steel and y8 isnt baffled and aluminium. thats all i can think of on the top of my head.. |
Re: (xtremeazian)
Springs/coilovers for '94-'01 integras and '92-'00 civics are interchangeable. The only difference is the spring rates.
Re: (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life »</TD></TR><TR><TD CLASS="quote">Springs/coilovers for '94-'01 integras and '92-'00 civics are interchangeable. The only difference is the spring rates.</TD></TR></TABLE>
but the 92-95 lca bushing that connects to the shock is thicker than the 96-00 so u will have to grind that bushing to make the 96-00 shock fit in a 92-95 |
Re: (HELLA!!! bonta-kun)
1992 Honda Accord Wagon Caliper is IDENTICAL to the caliper of the 01 ITR. The piston part, not necessarily the bracket, ill check.
Upgrading DX, LX, CX, HX 96-00 Civics requires the Knuckle from a 99-00 Si or a 96-00 EX for the mounting points for a bigger caliper. Get the Si knuckle if thinking of getting like 91-96 NSX, 94-01 Integra or bigger calipers. *Someone confirm with ACUTAL experience that the 96-00 Civic EX and SI Knuckles are IDENTICAL and that the calipers are identical. I know that someone with a 99-00 Si got pads from a 96-00 Civic EX and they didnt fit. 91-96 Acura NSX front calipers bolt onto a 3rd gen ITR, no grinding. Use the NSX pads but ITR rotors. 94-95 Legend GS 2 pot calipers also bolt onto a 3rd gen ITR, no grinding. Use the Legend Pads but ITR rotors. 94-01 Integra (-R) Calipers bolt onto a 99-00 Civic Si. 1996-1998 Civic 4 doors have taillights that are NOT interchangable with a 99-00 Civic 4 door. Different Shape. 1996-2000 Civic Hatches and Coupes taillights are interchangable within year (not coupe to hatch, obviously). 1996-1998 to 1999-2000 Front end conversion DOES require modification. requires the Hood, Bumper, Fenders, AND Headlamp assemblies. Also reccomended is to change to the 99-00 Radiator support, although this is a OEM perfect conversion, it can be ghetto rigged rather easily (and pretty effective) without the hassle of changing the support, as its a pain. Modified by Redline96LX at 1:43 AM 2/12/2005 |
Brake boosters from CRX's are the same as EG's, so if you're in a pinch, vandalize an EF https://honda-tech.com/forums/images...s/emsmilep.gif.
Re: (Archidictus)
By request: the 94-97 Accord coup B-pipe in the exhaust fits perfectly on 92-95 Civic coups and hatches https://honda-tech.com/forums/images...s/emsmilep.gif.
EDIT: flip it over and it tucks really high up in the exhaust tunnel, thus aiding lowered cars in their fight against speedbumps and potholes. |
Re: (Archidictus)
this thread makes me happy.
please go up for more info, and more happyness. |
Re: (smokee)
header back exhaust is interchangeable on d16 and b16 series depending on location of cat
Modified by civictildeath at 10:48 PM 3/31/2005 |
Re: (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">header back exhaust is interchangeable on d16 and b16 series</TD></TR></TABLE>
That is the dumbest thing i have ever heard, why try to kill the thread? |
a lower tie bar from a 92-95 eg and a integra one will NOT fit an ek b/c the ek one is noticably longer....i think that is right, please tell me if that isnt tru
Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (kleanlscivic)
94 and up Integra seats bolt into the 92-95 civic, for 96 and up (civics) we just swapped seat tracks and they bolted in. I don't know if the ITR uses a different pattern for seat tracks or not. Larry
Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (B18C4-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C4-T »</TD></TR><TR><TD CLASS="quote">94 and up Integra seats bolt into the 92-95 civic, for 96 and up (civics) we just swapped seat tracks and they bolted in. I don't know if the ITR uses a different pattern for seat tracks or not. Larry</TD></TR></TABLE>
i have the usdm itr seats in my civic, they are the same as the regular itr, 3 bolt lined up on my ek |
Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (eg92b16a2)
From my experience KLEANLSCIVIC is right when he said a rear lower tie-bar from a 92-95 civ\94-01 integra, will NOT work with a 96-00 civ.
The EK is wider, the teg\eg bar is to short. |
Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (gunnis)
Will a d16z6 crank pulley work on a d16y8, w/o any problems at all?
Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (Eibach95Civic)
I have confirmed that without a doubt the gasoline at the gas station is 100% interchangeable between all 92-00 civics. It will work in every one of them (maybe not the hybrids though?)
https://honda-tech.com/forums/images...s/emsmilep.gif |
as far as strut ans sway bars go i believe gsr and ctr tower struts are identical - the hot read color, if thats worth 50$ shipping from japan go for it, i believe its gsr and ctr front sway bars are all 22mm and they all look the same do they just bolt on? as for the rear its good i read this post i was 5 secs away from buying the rear lower tie bar from a gsr, do ctrs have rear lower bars? I think the ctr and usdm itr rear sway bars are both 22mm but the itr might require a kit or welding to mount up right? Jdm itr rear sway might be 23mm either that or ebay sellers are full of it, i read that ctrs have a bar reinforcing the bumpers is that part of the suspension? do integras have it? does any one know about the rear strut tower bars interchangeablity ? also when some one mentioned shocks struts springs and coilovers does this include swaping between 91-93 teg, 94-2001 teg 93-95 vic and 96-2000 vic, will the diferent spring rates be bad cause in any way or is more always better? i was thinking of getting the tanabe springs for either itr or 93 teg cause of higher spring rates than that of the ek take a look http://www.tanabe-usa.com/spri...?id=3 wow that was a long post thanks guys https://honda-tech.com/forums/images...es/emsmile.gif ps what about the rsx is anything swapable other than the motor?
arent all sideskirts interchangeable on 92-00 civics?
i was wonderign if head bolts are the same for 92-95 d15b8's and/or any other motor im tired of blowing head gaskets havce dx head on it. and t-25
thanks https://honda-tech.com/forums/images...es/emsmile.gif |
