Replacing the Left Front motor Mount?
Hey guys, im wondering if anyone can tell me if I have to remove the A/C compressor from the mount, to loosen the front lower motor mount bracket so I can slide the mount onto the bolt/spindle that screws into the mount on the engine....or do I just bend/force it on without having to remove the compressor? This looked easy before I started, so I might be doing something wrong to make it harder than it really is.
Any comments welcome!
Re: Replacing the Left Front motor Mount?
you dont have to remove it, just fiddle with the mount a little. Done it a few times, sometimes its a breeze other times not so much
If you are talking about the TORQUE mount of the AC, you can easily change it.
undo the mount via the two botls of course, then go topside and unbolt the timing mount from the chassis (ione bigass bolt)
use a jack to stabilize the motor, but let it drop 2-4 inches.
reverse for install
reverse for install
GIANT
03-10-2003 01:58 PM
