Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
What is this suspension noise?
Old 08-04-2010, 09:22 PM
fedex's Avatar
Default What is this suspension noise?
http://www.youtube.com/watch?v=eAahT2F5jAY
I'm not sure what component would be making this noise, Spring? Strut? Balljoint? Arm bushings?
It only makes the noise going up and down, turning left and right doesn't cause it unless its also going up and down at the same time. (Does that rule out balljoint?)
I have torn compliance bushings in both my control arms, only my driver side makes this noise though. If I hold the arm and push the car up and down I can feel the arm vibrating with the noise. Lubing the bushings didn't help at all, and it really sounds like it's loudest right by the balljoint.
Any ideas?
Old 08-04-2010, 09:33 PM
suds1485's Avatar
Default Re: What is this suspension noise?
sounds like the strut. does it seem to hit bumps hard?
Old 08-04-2010, 10:13 PM
fedex's Avatar
Not really, if you push down on the car it stops jumping after one bounce
Old 08-05-2010, 01:13 AM
lex09's Avatar
more than likely its your control arm bushing
Old 08-06-2010, 02:33 PM
otek // ek.dipn's Avatar
well.. if you want my 2 cents it might be one of those bolts are too tight and maybe a little rusty spray some wd40 on the bolts and see if it squeeks than
Old 08-06-2010, 08:28 PM
AutoXer's Avatar
WD-40 won't do much. If it is actually a bolt, which I don't think it likely, you'd need to use a penetrating lubricant like PB Blaster or Liquid Wrench.
I'm voting for dry / worn out bushing.
Old 08-07-2010, 04:11 PM
lazlong's Avatar
Sounds like control arm bushings. Check for dryness, cracking, movement of the bushings. Check your tie-rod ends, ball-joints,and sway links as well. If you have to replace tie-rod ends or ball joints get the greasable ones, they will last longer as long if you lube 'em regularly. Honda, Autozone, and Oreillys will tell you the control arm bushings are non-serviceable but, you can order 'em and press them yourself if you wanna save money.
They have good prices on bushings here: http://www.rockauto.com/
Old 08-07-2010, 04:17 PM
Plead da Fif
It Wasn't Me's Avatar
You can't use the ball-joints with zerk fittings, they get in the way.
Someone already tried it - https://honda-tech.com/forums/honda-civic-2001-2005-78/wheel-bearing-ball-joint-removal-replacement-2517273/
Old 08-08-2010, 12:46 AM
em2boy36's Avatar
thats from control arms bushings buddy.
Old 08-27-2010, 11:30 PM
fedex's Avatar
It was the stabilizer link, easy fix.
Old 08-27-2010, 11:32 PM
Plead da Fif
Good deal, thanks for updating the thread.
Davidgboogie
09-10-2017 09:11 AM
rjnyc
02-08-2010 10:20 AM
rhdins
05-22-2008 06:46 PM
da_33
07-10-2007 03:21 PM
92integraVTECgsr
02-18-2005 01:02 PM
Quick Reply: What is this suspension noise?
