Torque settings on the header?
hello im installing a header on the friends 04 honda civic would love to know the Torque settings on the header? any help would be much appreciated.
p.s i already searced it and couldnt find anything=(
its something light, 28 lb-ft comes to mind, but I'll check when I get home. Most of those bolts you won't be able to get a torque wrench on anyways, so tighten them up, but not too tight because you'll snap em, then drive around and check them, retighten if necessary.
Sanji
Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 »</TD></TR><TR><TD CLASS="quote">its something light, 28 lb-ft comes to mind, but I'll check when I get home. Most of those bolts you won't be able to get a torque wrench on anyways, so tighten them up, but not too tight because you'll snap em, then drive around and check them, retighten if necessary.</TD></TR></TABLE>
Also, to add to this, exhaust leaks are easy to spot, because they'll sound like deep puffs of air leaking through. I had an exhaust manifold leak on my Landcruiser, and all it took was some re-tightening on the surrounding bolts to close the gap.
Sanji
Re: (cranny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cranny »</TD></TR><TR><TD CLASS="quote">look for flat black stains works too.</TD></TR></TABLE>
Sometimes carbon takes a while to buildup, though. Especially on a fresh gasket replacement. And, carbon build ups are difficult to spot on warn gaskets already covered in carbon.
B18Redline
11-21-2004 11:20 AM
