Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Power Window Help
Old May 24, 2009 | 08:34 PM
stuckyville's Avatar
New User
Default Power Window Help
I have a 2001 civic LX. My passenger power window motor went on me. I have taken off the door panel and can see the motor. It seems complex to replace. Is there anyone else who has done this before and has pictures or can tell me more about my problem.
Any help would be great.
Thanks,
Stuckyville
Old May 25, 2009 | 04:55 PM
raulyd's Avatar
Default Re: Power Window Help
i have that same problem but i havnt fixed it! the most u can do is buy the motor and get it installed somewhere or if u do it urself just remember how and what u took off piece by piece. and the manual should help u somewhat!
Old May 25, 2009 | 08:08 PM
Zaza886's Avatar
New User
try hitting the motor slightly with a hammer ( DO NOT GO TOO HARD) that should do the trick i have a DX i had the same problem about a year it worked with me you should try it. :D
Old May 26, 2009 | 08:44 AM
Alfspeed's Avatar
I have an EX but the problem isn`t the motor, is the master driver power switch, I have Seen many civics 7th gen with this problem, test your window motor before replace it
Old May 26, 2009 | 08:48 AM
crx378's Avatar
yep, my pass window switch is not working either.
Old May 26, 2009 | 07:39 PM
New User
I am already replaced the master window switch on the drivers side. There was a buring smell and the circut board on the master switch was burned over the passenger side. However, after purchasing and installing a new one, the passenger does not work.
How would I test my motor? With a volt meter?
Old May 27, 2009 | 08:33 AM
Alfspeed's Avatar
my master window switch had the same problem, try with a 12v car battery or a power plant, in the window motor have a 2 wires plug, in these plug try put the positive wire in one pin and the negative in the other one, it does`n matter how you put it, if you change the wires it have to work donw or up, it have to work, if it doesn`t do anything it should be bad
Old May 27, 2009 | 01:54 PM
B18 Piston's Avatar
i have some siht going on with my driver side window.
brad8266
Jul 17, 2009 05:25 PM
da_ska
May 31, 2009 02:32 AM
bigm43
Feb 26, 2009 12:53 AM
justcosmo
11
Jul 25, 2005 07:11 PM
kings1ey
Jun 20, 2005 02:55 PM
