Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
P1361 Error Code
Old Jun 11, 2006 | 08:57 AM
jdandco's Avatar
Default P1361 Error Code
I had the error codes checked at Auto Zone and they said it was a P1361 manufacturer code. I looked it up on this forum adn found that it is the "TDC Sensor" intermittent interruption. The car will act like it is out of fuel and lose all power. If you shut it off for awhile it may work for 2 weeks before it happens again. Does anyone know where this sensor is and how to replace? Thanks
Old Jun 12, 2006 | 06:04 AM
Miracle's Avatar
Default Re: P1361 Error Code (jdandco)
Im thinking that its the Crank Position sensor.
It should be on the INSIDE of the timing cover, looking at the right side of the motor. Underneath should be the easiest way to get to it.
Correct me if im wrong.
EDIT: It is the CAM position sensor, located just beneath the camshaft on the right hand side of the motor. heres the info for it: part # 370598 SENSOR ASSY., TDC CYLINDER Retail: 49.32 Wholesale: 36.99
You can get it from <FONT COLOR="red">Here</FONT>. on that page on the exploded diagram, its #13.
Modified by Red_EMII at 12:50 PM 6/12/2006
Old Jun 12, 2006 | 08:50 AM
Newborn_'s Avatar
Grace Under Pressure
you're probably right, ive never had anything to do with the sensor on the d17 lump.
however, i work on Renault trucks and commercial vans and the CSP sensor on those is at the flywheel.
just another posibility...
Old Jun 12, 2006 | 03:45 PM
Miracle's Avatar
Default BUMP!!!
TTT
Old Jun 15, 2006 | 12:16 AM
LowTec MOHawk's Avatar
just thought id say that there is a Service Bulletin out for this code depending on the year and model of your civic, but the fix for it is a new cylinderhead because if the cam has excessive endplay it will throw a p1361 or p1362
Old Jun 16, 2006 | 08:46 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: P1361 Error Code (mikeformos03dx)
Here is the criteria for that bulliten:
Applies To: 2001 Civic EX – From VIN JHMES2...1S000001 thru JHMES2...1S001375
– From VIN 2HGES2...1H500001 thru 2HGES2...1H535885
– From VIN 1HGES2...1L000001 thru 1HGES2...1L040006
– From VIN 1HGEM2...1L000001 thru 1HGEM2...1L028506
if your VIN number falls into one of those categories then this bulliten probably applies to you
Old Jun 1, 2011 | 05:00 AM
emicha1's Avatar
Where I can find this servise bulletine?
P1361 code when the engine is hot
Thanks
Old Jun 8, 2011 | 09:39 AM
mrlover's Avatar
so what the solution to this problem?
Old Jul 7, 2019 | 10:01 PM
Tracecross30's Avatar
I just developed this same
issue with my 7Gen civic.
leonardsmith
Honda CR-V & Element
Dec 1, 2021 06:33 PM
C4st0r_Tr0y
Aug 12, 2018 08:08 AM
AMseven
Sep 22, 2009 08:37 AM
