d17 ?
1 Post
Re: (toyomatt84)
http://www.knology.net/~jediklc/pistonnotes.htm
Its a few down, doesnt seem like to much work. Probably cost u about $300 from a junkyard.
http://www.automotivehelper.com/topic189077.htm
Re: d17 ?
Sanji
Re: d17 ?
Well, you'd need to do something about the ECU, since there's no distributor on a D17. This would be an upgrade for previous gen. Civics, since it's a boost in displacement. But, it'd be a massive downgrade for the 7th gen. Civic, since it'd be such a hassle to get it running properly (not to mention the legality of the older engine parts on a newer chassis).
Re: d17 ?
Last I checked you needed to re-machine the snout of the crank in order to get this to work (you need the d16 crank gear) the main benefit is that the d16 head flows way better than the d17 head. the down side to this is your doing away with the coil pack system which IMO not worth it since you have so much control over it if you go k-pro.
Oh and there are a # d16 parts that are interchangeable with the d17
Clutch, flywheel, the whole valve train (ie. valves, springs, retainers), rod bolts, head studs, timing belt tensioner, theres a bunch more.
Our motor is like Canada it's the same but different
_BEN_
02-10-2005 07:13 PM
