problem with plugs and idle
Old Jun 21, 2005 | 11:14 AM
bennyhonda7's Avatar
Default problem with plugs and idle
k i run the car it idles at start around 1100 rpms...which is fine...a/f are around 14:1 at idle in boost 11.5.1-12.5.1 which is also good. when ive been boosting a little and stop at a light the idle drops to around 500-600rpms...and sounds like it has a stall or is stalling...i just but new plugs in today...zrf7f11 and gapped at .28 im running rich but not as rich as i was...after a 30 minute drive i checked the plugs and they are totally black from core to strap...what the heck is going on any help appreciated.
Old Jun 21, 2005 | 11:43 AM
MrBui's Avatar
Default Re: problem with plugs and idle (bennyhonda7)
hondata? this heat has my car running like yours and im down here in florida
Old Jun 21, 2005 | 11:53 AM
uberdata actually? could it be the heat? also I changed my plugs today...zfr7f11 gapped .28 and drove 30 minutes and they are blacker than ****....wtf?
Old Jun 21, 2005 | 12:12 PM
Qveon's Avatar
I have this same problem accept my plugs are black but the strap is past the bend towards the ring, but my a/f ratios are still lean.
I am 2 steps colder.
Old Jun 21, 2005 | 12:49 PM
do you have the idle problem also? and does it seem like the motor jerks or jolts around 10%throttle between 2000-35000 rpms if your just cruising...?
elliott_219
Engine Management and Tuning
Aug 21, 2010 12:31 PM
SuM Honda
Jan 1, 2010 07:29 PM
wwwbret
Nov 22, 2006 04:35 PM
shahram72
Dec 19, 2002 10:49 AM
