Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic 2004 si very bumpy??
Old 02-13-2013, 03:49 PM
azi90's Avatar
Default Civic 2004 si very bumpy??
I just bought a car 04 civic si .. the car runs well its just it is very rough on broken roads and unusually bumpy ... i dont think so i need to replace shocks or w.e considering car is fairly new .. like its just 9 years old ? and yeah i do noticed that alignment of my car is out .. would that be the reason ? if not how can i make it less bumpy as it is kind of embarrasing
Old 02-13-2013, 04:08 PM
lazlong's Avatar
Default Re: Civic 2004 si very bumpy??
In my experience the Civics are bumpy when brand new. I don't know weather it's because it's a small vehicle or the McPherson struts. Either way, the OEM struts and springs are pretty weak. I've had to replace mine (struts and springs) every 50-60K miles. You may just have worn out suspension.
Things that will make the ride more bumpy:
- different size wheels
- low profile tires
- lower vehicle
Old 02-13-2013, 04:18 PM
azi90's Avatar
- low profile tires
- lower vehicle
Its not brand new its second hand car .. 9 year old model.. so hold on do i have problem in suspension or struts ? or is it both ?
Old 02-13-2013, 04:39 PM
lazlong's Avatar
By suspension I mean struts but, there are 2 parts to the strut assemblies- the strut itself and the spring. Think of the strut as being a shock absorber but, instead of it cushioning the ride only it's actually an integral part of the structure.
I've just changed the struts and not the springs before but, ended up putting new springs on too. The OEM springs are pretty weak and experience spring sag fairly quickly.
Old 02-13-2013, 04:54 PM
azi90's Avatar
So its not the alignment thats causing the problem ?
Old 02-13-2013, 07:27 PM
lazlong's Avatar
Alignment wouldn't make it bumpy.
To test the suspension push down on a corner with your hand. It should go down, come up, then settle- that's it. Any more than that and you need new struts... and maybe springs.
Old 02-13-2013, 07:50 PM
azi90's Avatar
Ok so ya i tried doing that ... but damnn my car is too hard to make it bounce .. i mean like i was able to bounce my front bumper and the bounce was okay it was just once up and down but the back part i couldnt even push it down it was so hard .. could that mean there is some problem ? i tried doing it on my dads car just to make sure if im pushing hard and i was able to bounce that properly..
Old 02-13-2013, 08:06 PM
lazlong's Avatar
Yeah, the struts are either blown or seized.
Old 02-13-2013, 08:10 PM
azi90's Avatar
what the hell does that mean ? i need new one ? do i have replace the front ones tooo coz they seem pretty fine
if struts are blown i should be able to push the car down still .. it wont come back up tho ..
Old 02-13-2013, 08:34 PM
lazlong's Avatar
blown= they blew out and all the fluid leaked out
seized= rusted or seized due to grit and debris
Symptoms for both are as you described earlier- no bounce at all. Replace any strut that doesn't pass the bounce test.
Old 02-14-2013, 02:00 AM
Zedt3's Avatar
Does this guy even know if he has stock suspension or not? For all we know he could have inherited coilovers on that car or cut springs or some other horrid combo. He needs to post some pics of the suspension, if he doesn't know what he has.
Old 02-14-2013, 05:15 AM
azi90's Avatar
ill doo that .. but im pretti sure they are stock .. coz my car is not like lowered or anything
Old 02-14-2013, 05:39 AM
azi90's Avatar
here is the picture of suspensions ... seems stock to me
Old 02-14-2013, 11:21 AM
Belmont's Avatar
Is this your first car?
Old 02-14-2013, 04:05 PM
azi90's Avatar
yeah .. why? i used to drive my dads corolla 02 so its not like i dont have anything to compare my car with
Old 02-15-2013, 03:40 PM
lazlong's Avatar
bump
"Replace any strut that doesn't pass the bounce test."
doubleoazn03
04-03-2013 02:38 PM
fog raw
01-11-2012 08:36 AM
E55TOSI
Honda Civic (2006 - 2015)
10-23-2007 07:19 AM
92accordundrconst
01-29-2006 07:40 AM
mjrage
11-11-2003 10:12 AM
Quick Reply: Civic 2004 si very bumpy??
