2001 Honda Civic
Re: 2001 Honda Civic
its pretty obvious but unless u get the rods off and away from the locking assembly..your'e ****ed. I couldn't get the rod off the handle when i was replacing the lock actuator...its a bitch...but goodluck.
There's a retainer clip (looks like a bent piece of coat hanger) tucked behind the bracket that the cylinder mounts to. Have you removed it? You can access it just beneath the cylinder. Pull it down to remove it.
Then just pull the handle up, and out. (like you're opening the door)
Jakester9500
03-01-2012 12:00 PM
