Code 10 and 22??Please Help...
Old Sep 26, 2004 | 01:31 PM
XzzYzzX's Avatar
Default Code 10 and 22??Please Help...
Ok I put a second gen b16 in my 92 dx hatch runs fine wit the p30 hook up the knock senor and not throwing a code even when i take it out doesn't throw a code weird but i am throwing a code 10, IAT so i took that off and it was broken so i put my gsr on on there still throws the code, secondly i am throwning code 22 vtec pressure valve so i replaced the solniod wit my gsr and still throwing the code?? I guess i should test both senor but wat other things could make this happen. sorry for the long post. Thanks
Old Sep 26, 2004 | 02:32 PM
XzzYzzX's Avatar
Default Re: Code 10 and 22??Please Help... (XzzYzzX)
Update: I did a quick search and found out the the presure switch is the green sensor so i put my gsr on in there vtec works.....now for the last problem code 10 i replace the sensor but i have two sensors on the harness that is open gray and white which on goes to it...thanks
Edit:Found out it is the white plug wit the green and red wiring but still throwing the code??
Old Sep 26, 2004 | 06:54 PM
XzzYzzX's Avatar
Bump...Anybody??
Old Sep 28, 2004 | 11:41 AM
XzzYzzX's Avatar
Help!!!
Old Sep 29, 2004 | 01:01 AM
Waachback's Avatar
Reset your ecu? I also had a code 10 before, I got rid of it by changing my dizzy ( weird yea I know).
hondachris1994
12
Aug 15, 2008 03:13 PM
drewboy
May 14, 2005 10:03 PM
smkngsr
Oct 22, 2001 08:05 PM
