► 01-05 Civic Suspension Q&A (coilovers, springs, bars, etc)
#2626
Re: ► 01-05 Civic Suspension Q&A (coilovers, springs, bars, etc)
when i got my car it had new monroe quick struts on it and they didnt last 1 year
#2627
Sanji
I've decided I'm just going to let the mechanic do the struts. I don't want to mess with a spring compressor, and I still would need them to install the bushings for me as well. With that being said, what is a good cost effective option? I want to use stock springs, I drive in the winter a lot and don't want the car lowered. Would cheapo Monroe Struts work as well? Here's my list so far:
4 Hard Rubber Bushings
2 Koni Orange Front Struts
2 Koni Orange Rear Struts
4 Wheel alignment
How much can I expect to pay the labor for someone to install this for me?
4 Wheel alignment
As for labor, it's going to be tough to give you an accurate estimate, since out here... shops vary tons! If you can find a reliable corner-shop, that may save you some serious coin and you could probably get the install and alignment done for under $300.
#2628
I've had great luck with Monroe's on passenger vehicles, even on harsh roads in Winter. I would say, if you're trying to keep it budget conscious, they're a good alternative (especially since Rock Auto stocks them).
I'm looking for a link for the control arm bushings I see so many different brands and whatnot. Is there a particular variant you guys recommend?
#2629
Sanji
Good to know. I might go this route. I have an 01 Civic EX with 160k miles, just need something to get her going for awhile!
#2630
I only see them for the 95-00?
Nvm Found them
$100 a set, ew.
Going to go Energy Suspension instead. $50 for the set.
http://www.energysuspensionparts.com...p?prod=16.3116
That all I need for front bushings? This with Monroe Struts I shouldn't be in too bad of shape to get me by.
Nvm Found them
$100 a set, ew.
#2631
Sanji
Nvm Found them
$100 a set, ew.
Energy Suspension 16.3116 Front Control Arm Bushings Made by Energy Suspension
Nvm Found them
$100 a set, ew.
#2632
MOOG makes a new control arm bushing you should take into consideration.Innovative MOOG control arm bushing design makes it longer lasting and easy to install - MOOG
#2633
Just want to confirm Part Numbers before I press the order button:
MONROE Part # 71434 Left Front Strut $81.79
MONROE Part # 71433 Right Front Strut $81.79
MONROE Part # 71340 (I didn't see a left or a right, safe to assume I just order 2 of this part number for the rear set?) $66.79 * 2
Bushing:
Moog Front Control Arm Bushings K408 (Is this the right set you guys talk about? Was cheaper than the Energy Set) $20
Bushing:
#2634
I've changed my mind yet again as I'm fixing other issues with the car.
I want to just get a whole pre-assembled strut assembly package. Any thoughts on Unity Automotive?
http://www.completestruts.com/2001/h...t-honda-civic/
Monroe actually sells some, are there any alternatives to get assemblies from? KYB doesn't make any for this car
Monroe 171434 Front
Monroe 171433 Front
Monroe 171340L Rear
Monroe 171340R Rear
Correct struts and bushings for my car? Would Monroe just be the go to for strut assemblies? Any other hardware I should get?
Monroe 171434 Front
Monroe 171433 Front
Monroe 171340L Rear
Monroe 171340R Rear
#2635
monroe would be the last place i would consider getting pre-assembled struts and thats not saying much. look into KYB,tokico its more money but they will last longer in the long run. or maybe those brands don't come in kits im not sure but its your money and you mite just end up in the same boat your in know minus your hard earned money.
#2636
It's been a while since I last posted but my Tokico D-Specs on GC Sleeves are still working fine. I have put quite a few miles on them now.. Not sure if those shocks are still sold for EM2. Great setup for everyday commuting IMO.
#2637
Monroes aren't that bad for everyday driving. Had them in my 4Runner before I sold it.
Complete set front and back will run me $368. Now I need springs. I want either stock height or a modest .5" drop (I drive in the snow with this, don't want it that low)
TEIN S.TECH Lowering Springs be okay? They're on sale for $160. These shouldn't slam my car right?
Do I need to replace my tophat? Buddy said stock ones get worn and it might be a good idea to get a new one. Any specific one I need?
#2638
I hate how indecisive I am. Going Koni Orange I guess.
I would go for the Eibach Pro Kit if you are looking for a mild drop. If you want, save up for some coilovers or ground control sleeves. Both can be adjusted to whatever height you want.
#2639
I live in NH, in the northeast. We get some snow.
I actually looked at the Tein H Tech and they're less of a drop than both the Eiback and the S Tech. Thoughts?
I'm actually seeing the Eibach for $200 shopping elsewhere...maybe I'll go with that.
I like this setup now.
Koni Orange front + back
Eibach springs all around
Energy Suspension LCA Bushings
Replacing ball joints while I'm at it too. What are decent ball joint brands?
#2640
Not trying to dump a couple grand into the suspension of a car worth $4k. My next car will be a Saab 9-2x That one I might dump some money in.
#2641
#2642
Stupid question, most of my experience has been with double wishbone hondas so I am not sure if I need to order additional parts, but here goes.
For my 2002 Civic, I replaced the struts last year without changing the strut bearings, I know stupid mistake, they were clunking and making noise before and still are making noises and pretty much narrowed it down to the strut bearings.
My question is, I bought the OEM metal bearings, would I need to buy new tophats? or do I just replace the old strut bearings and use the existing tophat components?
#2643
Hello guys! I had my Eibach Pro Springs + Koni Struts installed for a few months now. I'm now hearing some road noise, which I've narrowed down to the rear driver wheel. Went to have my alignment checked, and they said my Lateral Rear Arms are worn, and non-adjustable. Currently have 2.5degrees unintentional camber!
I have 2 options for new Rear Arms:
SPC Rear Camber Kit SPC 67230: eBay $100 for the pair
Megan Racing Camber Kit MRS-AC-0710: $85 for the pair
MOOG K90351L: $75 for the pair
Ordered Moog.
My car has a very mild 1" drop. Looking for something that will last. I don't want to spend a lot either, so I'm leaning toward the Megan Racing Kit. Do I need to buy anything else or will the kits come with new bolts and whatnot?
Ordered Moog.
#2646
coilovers HELP!!
Hi guys so I'm a little new to the honda scene, I just bought a 2002 honda civic (es2) it's lowered but I'm pretty sure that the setup is shot due to really bad pop in the front right side, same tire has really bad wear on the inner tire whereas the other 3 look brand new.. anyways I'm trying to find a new coilover setup that is good I've been looking at Racelands but I've heard some bad things, anyone know a good brand for coilovers that will put my car around 2-4 inches lower than stock height?
#2647
Re: coilovers HELP!!
The pop noise can either be the coilovers set wrong, or the control arm bushings. Racelands are garbage. And 2.5 - 4 inches is an insane drop, and you will have problems, scrapping, bad ride.
What's your budget? Koni yellow struts and shocks and ground control coilovers are a great budget combo.
#2648
My budget for coilovers at this moment is around 600 to 800, I'm taking my car in to the performance shop next week to try and find out what's going on for sure but if I need new coilovers then I'll be looking around that price range. I want to go accuair but I'll have to save for that so I need something quality to hold me over until then
#2649
Sanji
#2650
Re: ► Official EM2/ES1/ES2 Picture Thread (1.1)
Just wandering if I were to buy a half set of the D2 coilovers just for the rear would it take some of the bounce out of the ride ?
