steering wheel problems
Old Dec 30, 2006 | 01:28 PM
hellcivic1996's Avatar
Default steering wheel problems
I bought a steering wheel and decided to put it on my 96 civic read the steering wheel thread got the old one off no problem put the momo hub adaptor but the steering wheel is off to the right when i drive straight.How do i fix this and what tools ae needed to get the hub adaptor off.
Old Dec 30, 2006 | 01:29 PM
WhiteSlips's Avatar
Default Re: steering wheel problems (hellcivic1996)
Use a lug wrench, take the hub off and adjust the steering hug whichever direction you need to.
Old Dec 30, 2006 | 03:51 PM
Default Re: steering wheel problems (crstfr14)
i get as far as taking the 19mm bolt off but i still cant get te hub off. I cant see anything holding it on.
Old Dec 30, 2006 | 07:35 PM
WhiteSlips's Avatar
After you take the 19mm bolt off, the hub should just slide right off, if not use a flat head and pry it off.
Old Dec 30, 2006 | 08:53 PM
RDub's Avatar
grab a small pry bar and hook it on the hub and pull it off
Old Dec 31, 2006 | 12:50 PM
Default Re: steering wheel problems (RDub)
dude this hub is tighter than a virgins pussie it aint going no where but i wil try your suggestions.
Old Dec 31, 2006 | 09:12 PM
RDub's Avatar
mine was tight as hell when I tried to remove it too. I thought I was going to break it yanking on it with the pry bar. It took a few good yanks but it eventually broke free..
Old Jan 1, 2007 | 03:32 AM
thanks man i just wanted to make sure i was going to brake anything
eesuh
Aug 15, 2008 02:36 PM
dustin_crxsi
Oct 30, 2006 05:29 PM
Sijray21
Feb 28, 2006 08:33 AM
mykal
16
Oct 2, 2004 01:41 PM
ff terror
Sep 17, 2004 11:24 AM
