How to remove the steering wheel, Nut
Old Oct 27, 2006 | 06:34 PM
dustin_crxsi's Avatar
Default How to remove the steering wheel, Nut
Im replacing the blinker switch colum. For the nut thats in the middle of the wheel, I just get a socket to put in there, and give in hell? Im kinda scared to break the steering colum.
*for a 89 crx si*
Any one did this before, or could help me out?
Old Oct 27, 2006 | 07:30 PM
Default Re: How to remove the steering wheel, Nut (dustin_crxsi)
anyone?
Buller....Buller....Buller?
Old Oct 28, 2006 | 02:07 AM
DC2_005200's Avatar
awww dont worry. just make sure that you lock the steering wheel so that you arent turning the steering wheel as you are trying to break the nut loose.
Old Oct 28, 2006 | 06:52 AM
jllong95's Avatar
or if you access to an impact that works well to
Old Oct 28, 2006 | 06:43 PM
N1 Andy's Avatar
R.I.P. Andy
Default Re: (jllong95)
give 'er hell, you wont break the column, but yeah impact works great too
Old Oct 29, 2006 | 05:35 PM
sweet. I appricate it.
Old Oct 29, 2006 | 07:31 PM
s2k24's Avatar
if you can get access to an impact gun that would be a piece of cake. if not just lock the steering wheel in place and use a 1/2 inch ratchet or whatever you have. when you get the nut loose you should just screw the nut on the threads a little bit and pull as hard as you can on the steering wheel because usually the steering wheel gets stuck on there pretty good. that way the nut stops the steering wheel from flying in your face.
Old Oct 30, 2006 | 05:29 PM
marcusgnf's Avatar
Default Re: How to remove the steering wheel, Nut (s2k24)
tire iron
89civichb20b
Sep 13, 2015 11:11 AM
ek_will
Dec 29, 2005 07:45 PM
peel17
Dec 5, 2005 02:40 PM
b16acrxer
10
Dec 2, 2003 06:28 PM
SloVXHatch
Jul 18, 2002 07:56 AM
