♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
Old 08-30-2010, 01:12 PM
  #27626
Hayce's Avatar
Default Re: ♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
I have RHD EK and used the spacer too, no issues with lack of thread and like ^ think it looks fine.
To the guy with the loom hole pic, should have moved it down a bit further (imo). There was a pic on the first page...
Old 08-30-2010, 03:24 PM
  #27627
turbob18si's Avatar
Any thoughts or opinions on doing a booster delete using the stock master cylinder? is it possible?
Old 08-30-2010, 03:29 PM
  #27628
Pimpin' Pimpin'
BrandonRyan's Avatar
Take your oem master off your booster then look at what your working with. i did.. The booster pushes a free floating ROD inside the coupler of your master.
You have to modify and make some type of rod that will rest inside of your master.... it is very possible... and can be done with little or no money.
I messed with it for a few hours.. Got frustrated and went with a 80$ wilwood master. Sold my 1in OEM master for more then i paid for my wilwood.
This is the post i found a year ago, and tried to replicate what he did. http://www.redpepperracing.com/forum...9&#entry273199
Also.. here is index of other DIY stuff he has done. Incredible. http://www.redpepperracing.com/forum...4&#entry307594
Old 08-30-2010, 04:20 PM
  #27629
turbob18si's Avatar
is it a single or dual outlet wilwood? Im not tucking the lines on this project just deleting the unneccesary stuff
Old 08-30-2010, 10:14 PM
  #27630
Professor_X's Avatar
Originally Posted by JDMdecals
If your car isnt RHD, you can get away without using one. Just some modifications are needed. Or... If you just dont want to modify a $90 clutch master then get a spacer...
I personaly have RHD and needed the extra clearance.. and didnt like the idea of modifying a new clutch mater... The spacer removed 2 issues that i didnt have to even worry about.
Freeing up more time, for the other 1,000 issues im faced with this build.
Here is a photo of mine.
I don't think it looks bad. Thats why i have one. If it bothers you the way it looks.. then dont get one.
Do you have enough space to fill up your brake master cylinder?
Old 08-31-2010, 06:28 AM
  #27631
Pimpin' Pimpin'
The photo is deceiving. I have a good amount of room to get the reservoir cap off to fill it with a funnel.
Thanks man. Its kinda dusty right now. been sitting for weeks.
Old 08-31-2010, 01:20 PM
  #27632
ek4kid's Avatar
iv searched and gotten mixed results. but, im flaring ss hardline for my brakelines. and im tryna figure out a good flare tool for the 37 single flare. i was thinking about the ridgid 377 but i one guy said he only got 6 flares good and the rest was bad? has anyone had troubles with their ridgid 377 flaring stainless steel hard line? need to get one asap to start my swap lol..
Old 08-31-2010, 04:07 PM
  #27633
jdmdohcek98's Avatar
i actually already have a spacer but i was looking for a way to avoid using it. when test fitted it with the spacer under dash when i tried bolting the cmc i had maybe 2 threads. how much thread did you get? how thick is your spacer?
Old 08-31-2010, 08:45 PM
  #27634
Pimpin' Pimpin'
if your spacer is too thick.. hit it with a da sander with some 80grit. thats what i had to do.... then again.. i got the prototype of the all-in-fab spacer.
Then he reproduced the spacer based upon my findings.
Old 09-01-2010, 05:33 AM
  #27635
phunhaus's Avatar
If you're LHD, just thread the shaft up another 1/4 to 1/2 inch and move the jam nut back. That's all. You don't have to waste money on a spacer. The money is better spent on a tap and die set you'll use over and over again in your garage.
Old 09-01-2010, 07:02 AM
  #27636
I have a tap and die set but my question is if i move the jam nut up 1/4 to 1/2 inch up will it shorten the travel of the shaft? i think if i did that then the shaft on the cmc wouldnt be able to go all the way in. i may be wrong so thats why i am here to find out.
Old 09-01-2010, 07:06 AM
  #27637
crazyjetsfan22's Avatar
This is what i did too but i was having trouble with getting the pedal to be at the right height and not stay on the floor. I ran out of time before IA and put the stock one back in. Over winter i am going to mess with it again. It took about 5 min with the tap and die.
Old 09-01-2010, 07:56 AM
  #27638
Pimpin' Pimpin'
You'll prob have to cut the shaft a bit also so the shaft dont slide up through where your pin slides through attaching your pedal arm.
Old 09-01-2010, 08:55 AM
  #27639
phunhaus's Avatar
You'll be fine. The shaft doesn't determine travel, the pedal arm does. You're only adjusting where the pedal arm contacts the shaft.
You shouldn't have to cut the shaft. When I did mine (before I realized I had to use a spacer for RHD applications) threading the shaft up and bolting everything together resulted in no-contact between pedal arm and shaft-end and allowed plenty of room for the clevis pin.
Moral of the story: if you have a LHD vehicle, buy a tap and die set.
Old 09-01-2010, 09:08 AM
  #27640
Yeah it just needs adjustment i was messing with it the night before i left NY to go to IA at about 10pm so i said F it put stock in and go to IA.
I dont really like the look of the spacer. I dont have anything polished on my bay so it would look out of place.
Old 09-01-2010, 03:31 PM
  #27641
the up and comming's Avatar
Just got my power prob can't wait to put it in use next week !!!
Old 09-02-2010, 04:59 AM
  #27642
oneoffaccord's Avatar
does anyone know what color this is hb is. my little brother wants to know
Old 09-02-2010, 07:42 AM
  #27643
mymmeryloss's Avatar
looks green to me
Old 09-02-2010, 07:54 AM
  #27644
prjct92eh2's Avatar
looks light blue to me
Those of you that have a booster still, are you still using the check valve on the vacuum line?
Old 09-02-2010, 08:55 AM
  #27645
phunhaus's Avatar
Yes, you must.
Old 09-02-2010, 09:30 AM
  #27646
prjct92eh2's Avatar
cool, just making sure. put mine on last night.
Old 09-02-2010, 10:51 AM
  #27647
[Ennis_D]'s Avatar
/\ That valvecover looks good there Jimmy
Old 09-03-2010, 09:53 AM
  #27648
Default need some opinions
I need some help deciding what color valve cover I should do. Its a 97 civic hatch factory roma red, sir bumpers so most of the trim will be black. Its also going to have spoon calipers and time attack white ce28n's. also going with black fittings and black braided hose. im thinking a spoon blue valve cover or a gloss black valve cover. give me your opinions or maybe some red ek's with different color valve covers , cause I havent been able to find any nice pics.
also ive heard its not a good idea to run the black braided hose under the car because it can break. i have a fuel cell so i am wondering how everyone else with black hose is doing this?
Old 09-03-2010, 11:54 AM
  #27649
spoon valve covers are yellow...
Old 09-03-2010, 12:14 PM
  #27650
Pimpin' Pimpin'
^unless you paint over them.
Quick Reply: ♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
