My K24A2 swapped JRSC DC5
Old 12-30-2011, 07:15 AM
  #76
DC5/EP3 MOD :)
Type-Spaz's Avatar
Default Re: My K24A2 swapped JRSC DC5
Originally Posted by ketchup!
lol. can't leave it alone can ya
would you expect anything less for me?! lol
Old 12-31-2011, 07:04 AM
  #77
01typerboi's Avatar
one clean DC5
Old 01-01-2012, 11:39 AM
  #78
DC5/EP3 MOD :)
Type-Spaz's Avatar
ok more build update!
Spent the day with my buddy Phil again and we went to town. Grinding and cutting and removing the seam sealer and even teased ourselves a little by trying some hardener.
Before:
After:
this stuffs a pain in the ***
Started grinding down some of the welds...
and for fun tried out some hardener
Old 01-02-2012, 07:40 AM
  #79
DC5/EP3 MOD :)
Type-Spaz's Avatar
Anyone know the best way to smooth out the seams like on the shock towers?
Old 01-02-2012, 08:41 AM
  #80
Sanji
toyomatt84's Avatar
Stitch weld them, and use some seam sealer between the stitches. Strength > looks.
Old 01-02-2012, 11:45 AM
  #81
fmchonda's Avatar
UNIQUE MASTERPIECE !!! love your rsx a lot !! the osm silver paint along with the stanced wedsport shoes and the supercharged k series power plant you didn't stopped there you have completed the whole car with the oem+ interior !!!
Old 01-02-2012, 03:07 PM
  #82
CA6VTEC's Avatar
Old 01-03-2012, 03:22 PM
  #83
pinnacle-r's Avatar
Did you perform a tuck in the engine bay??? If so, what did you do???
Old 01-04-2012, 07:43 PM
  #84
DC5/EP3 MOD :)
Type-Spaz's Avatar
nothing crazy but spent a couple of hours grinding again tonight... oh the joys.....
I know I have lots to go and some or sloppy as i got bored... but friday I will continue...
I also removed more seam sealer
  #85
DC5/EP3 MOD :)
Type-Spaz's Avatar
I've done so much... kinda hard to list
Old 01-07-2012, 03:04 PM
  #86
DC5/EP3 MOD :)
Type-Spaz's Avatar
So my buddy Phillip came down and we went to town on the bay last night. As I said we focused on filling the bigger holes.
cleaning metal to weld up
Testing fit
Tac in place
Weld
and walla
same thing with the old brake line holes
but placed the metal in the back side
The ultimate hole filled.....
traced out our pattern
cut it out
start welding it in
then started sanding it down
Then Phillip started some filler
also started welding and smoothing the motor mount
Not going to work on it tonight... but I'll keep cleaning up tomorrow
Old 01-08-2012, 10:03 AM
  #87
DC5/EP3 MOD :)
Type-Spaz's Avatar
great friend of mine hooked me up with a full energy suspension bushing kit awhile ago and I haven't done anything with it yet. But since my car is all apart I figured I'd finally get around to doing something with it.
I havent installed anything yet and will shortly but damn did I get all upset at my car last night... everything came out like butter until the very last bolt...
So I lit that bitch on fire!
and grabbed the cut wheel
what a pain in the *** now I need to clean out the old bushing still
and this is the mess it left
Old 01-08-2012, 11:39 AM
  #88
Sanji
toyomatt84's Avatar
Gusset that subframe and those lower control arms, while you're at it.
Old 01-08-2012, 05:24 PM
  #89
DC5/EP3 MOD :)
Type-Spaz's Avatar
what the **** is gusset?
  #90
DC5/EP3 MOD :)
Type-Spaz's Avatar
Ok spent another four hours in the garage today working on this bay...
used a wire brush to clean up some of the back firewall
and here are my main two tools for grinding
So I cleaned up some of the new fill plugs
before:
after:
before:
after:
(we will fill in the middle)
and here is my bay as it sits currently
Old 01-09-2012, 01:14 PM
  #91
Floeh6's Avatar
Awesome build, congratulations, it is perfect to me!
Old 01-09-2012, 01:59 PM
  #92
Axix24's Avatar
The bay looked great before.. You got WAY too much time on your hands... hahaha
Old 01-14-2012, 08:17 PM
  #93
DC5/EP3 MOD :)
Type-Spaz's Avatar
So we decided that it would be better to weld everything verses weld some and mud some... so I spent the first part of the night trying to remove all the filler we had previously laid
then cleaned so we could weld
had a lot of troubles with the welder. I had to go get a new tank of gas an then had to go get new rod as I ran out of both... then we couldn't get the welder adjusted correctly at first so it was welding like crap. We eventually got everything smoothed out and it started welding smoother
spent hours grinding lol
I know it looks rough... my back was hurting
and then welded up the other side after I cleaned out the filler
as she sits
Old 01-14-2012, 08:18 PM
  #94
DC5/EP3 MOD :)
Type-Spaz's Avatar
the worse part is I don't... working two jobs and trying to do this sucks
Old 01-15-2012, 03:30 PM
  #95
DC5/EP3 MOD :)
Type-Spaz's Avatar
So I spent around 5 hours today working on the damn car... man this is a lot of work... and I feel like I haven't even made a dent in it!
so here was where I started
pain in the *** and no where done
started griding and didn't like how it was looking
so I, yes I, rewelded it.
also rewelded the bottom of this section
and added more filler to the side
then started focusing on the other side
grinded down
started the sides
and spent a lot of time here
hard to tell but it's looking great IMO. Some filler will clean it up alot and smooth it out great!
Old 01-22-2012, 02:10 PM
  #96
DC5/EP3 MOD :)
Type-Spaz's Avatar
So I took a break from the bay today and focused on my engine. I just wanted to seperate it from the trans and get it on a stand. I will start working on it from here now
So here is what I started with:
Then I started pulling off the supercharger, harness and misc
and to be safe started boxing up all my parts lying around
Busted the engine hoist back out
lifted her up so I could take the trans off
then pulled the trans off
threw it up on the stand
and done
Old 01-28-2012, 02:18 PM
  #97
DC5/EP3 MOD :)
Type-Spaz's Avatar
redid my FPR again today while I'm finished up welding.
So I made a template
cut it out
smoothed it out
drilled the holes
test it out
bolted it where I'm running it
welded it quick
and sanded it down
I'll clean it up more later when I get to this side. Phillip went to town starting the driver side and I must say HOT DAMN
it is so smooth and gonna look sick
Old 02-05-2012, 07:25 AM
  #98
DC5/EP3 MOD :)
Type-Spaz's Avatar
So started pulling out my interior too....
pull out the backs next
poor car lol
Here are all of my bars lol
Old 02-05-2012, 08:02 AM
  #99
jxs1984's Avatar
coming along nicely. subscribed.
Old 02-05-2012, 08:10 AM
  #100
elitezdc5's Avatar
lots of energy drinks i see lol
Quick Reply: My K24A2 swapped JRSC DC5
