How to remove paint from your valve cover?
Well how do you do it????? I just got my VHT and i wanna get sprayin. Paint thinner dip? Thanx in advance
Re: How to remove paint from your valve cover? (Lost_in_a_world_so_cold)
try paint stripper , just spread it on and let it sit a few minutes. should wipe right off. Make sure you have all the gaskets off though , probably not to good for them.
"Aircraft" paint stripper.. I think it was at Kragen/Autozone.
This stuff works really well.
Spray it on, let it sit a few minutes, and then wipe/scrape the paint off.. just dont get it on your hands...
Re: How to remove paint from your valve cover? (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX »</TD></TR><TR><TD CLASS="quote">"Aircraft" paint stripper.. I think it was at Kragen/Autozone.
Spray it on, let it sit a few minutes, and then wipe/scrape the paint off.. just dont get it on your hands...</TD></TR></TABLE>
No need to wipe or scrape, just hit it with the water hose
1 Post
like everyone said..."AIRCRAFT Paint stripper" worked AWESOME...literally ate away paint within a matter of seconds..and then just a few minutes later i was able to run it with water and everything just dissapeared!
Re: (rjay8604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 »</TD></TR><TR><TD CLASS="quote">This exact ****, it will literally dissolve in front of your eyes:
Thats the stuff
Thats the stuff
Re: How to remove paint from your valve cover? (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">No need to wipe or scrape, just hit it with the water hose</TD></TR></TABLE>
Yeah, when I said scrape, I just was thinking of when I did mine, and I used a putty knife to kinda "push" a bunch of the released paint off of the valvecover. I used a hose later, but I got the big flat spots clear with a rag and the putty knife.
That stuff is killer, I still have a patch of dead grass from where I used it roughly a month ago, and it probably took less than 4 minutes to eat through my rubber gloves
Re: How to remove paint from your valve cover? (Nisif)
pressure washer works AMAZING. i used one the past weekend, at 2000psi, and it tore every inch of paint right off it
Re: How to remove paint from your valve cover? (2fast4udude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4udude »</TD></TR><TR><TD CLASS="quote">pressure washer works AMAZING. i used one the past weekend, at 2000psi, and it tore every inch of paint right off it </TD></TR></TABLE>
funny ... now that u mention it.... i'm boostin at 2000psi =P
good tips everyone!
good tips everyone!
