engine cleaning
Old Jun 5, 2003 | 12:45 PM
THE94GSR's Avatar
Default engine cleaning
what is the best way to clean the engine and what products have u guys used... also what do u have to cover besides the dist. cap.
Old Jun 5, 2003 | 12:59 PM
Seedc2's Avatar
Default Re: engine cleaning (THE94GSR)
https://honda-tech.com/zerothread?id=501990
I just covered my distributor and my intake filter.
Modified by kendogg at 10:33 AM 6/21/2003
Old Jun 5, 2003 | 02:01 PM
Stebo77's Avatar
I would say definintly cover the spark plug wires and plug holes, I power washed my engine when i first got the car, and water got on the plugs, the car would hardly move, I had to drive around and find somebody with an air compressor to blow the air out. Just be careful with all the sensors and ignition.
Old Jun 5, 2003 | 02:07 PM
VTECorona's Avatar
Default Re: engine cleaning (Stebo77)
Try doin a search dude, I've seen this covered a few times...
Old Jun 6, 2003 | 07:38 AM
deepgreengsr's Avatar
Default Re: engine cleaning (97RedTegGSR)
I like to use a Steam Cleaner and leave the engine running, the steam really gets it shiny! and always cover the dist. If it runs like **** afterwards just pop off the cap and dry it out.
Old Jun 6, 2003 | 07:56 AM
Caffeine Slug's Avatar
Default Re: engine cleaning (deepgreengsr)
The couple times I've done it, I just sprayed some Simple Green on the greasy stuff and hosed it down. Let it dry a couple hours and it's good to go.
Old Jun 6, 2003 | 11:42 AM
B2FiNiTY's Avatar
Gunk Foaming Engine Degreaser works wonders!
Old Jun 6, 2003 | 12:27 PM
B18Redline's Avatar
Default Re: engine cleaning (kendogg)
I feel like a dumbass asking this as I should know, but where is the distributor on a gen 3 integra?
thanks
Old Jun 6, 2003 | 12:44 PM
Phoenix_ITR's Avatar
Default Re: engine cleaning (Redline07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline07 &raquo;</TD></TR><TR><TD CLASS="quote">I feel like a dumbass asking this as I should know, but where is the distributor on a gen 3 integra?
thanks</TD></TR></TABLE>
left side of the valve cover.
Old Jun 6, 2003 | 12:48 PM
fivespeedintegra's Avatar
Default Re: engine cleaning (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Gunk Foaming Engine Degreaser works wonders! </TD></TR></TABLE>
Old Jun 6, 2003 | 01:44 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: engine cleaning (fivespeedintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fivespeedintegra &raquo;</TD></TR><TR><TD CLASS="quote">
-WOW
When I did mine, I covered everything up, sprayed simple green ALL over it, let it sit 15 minutes, more simple green, then rinsed. Wasn't as clean as above, but pretty clean.
-Will
Old Jun 6, 2003 | 03:19 PM
Default Re: engine cleaning (integra707)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra707 &raquo;</TD></TR><TR><TD CLASS="quote">
-WOW
-Will</TD></TR></TABLE>
that's my car....used the gunk method
Old Jun 6, 2003 | 08:22 PM
Dee's Avatar
Dee
Armor oil wipes and elbow grease!!
Old Jun 6, 2003 | 09:32 PM
R.S.'s Avatar
yea i used tha gunk **** and it worked great!
here is an older pic, it's even cleaner now:
Old Jun 6, 2003 | 09:48 PM
LSvtec03's Avatar
i hear pressure washing and steam can be harmful. this isnt from experience, though, just hearsay. gunk and simple green are my choice
Old Jun 6, 2003 | 09:54 PM
Dee's Avatar
Dee
Default Re: engine cleaning (LSvtec03)
I have pressure washed engines many times with no problems. Just follow the same rules for using engine cleaners. Stay clear of the alternator! I always leave the engine running when I use a steam cleaner.
Old Jun 6, 2003 | 10:03 PM
LSvtec03's Avatar
Default Re: engine cleaning (Dee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">Stay clear of the alternator!</TD></TR></TABLE> should that be covered up too? i hear yes and no on that
Old Jun 6, 2003 | 10:07 PM
Dee's Avatar
Dee
I have actually steam cleaned a running alternator after having a freaky oil filter accident but everyone suggest avoiding the alternator when steam cleaning. I know firsthand about the evils of getting engine cleaner in an alternator. Nothing like a BBQed charging system .
Old Jun 6, 2003 | 10:13 PM
Sukebei Oni's Avatar
just wipe it down once a week with a wet towel.
Old Jun 6, 2003 | 10:59 PM
Dee's Avatar
Dee
Default Re: engine cleaning (Sukebei Oni)
sukebei oni = horny demon... bwahahhaha
Old Jun 6, 2003 | 11:29 PM
ISELLRIGHTHANDDRIV
Guest
Posts: n/a
if not simple green use Power Clean, you can get it from Auto Zone too!! (use the purple onE) spray everywhere and anywhere you want in the engine bay, let it sit for a minute and hose off. cover everything like everyone says!!! then it's best to use a air hose to blow out all the water so none gets in your sensors or anywhere else, etc. etc. then, use some armor all and spray everywhere. soak everything. let it sit and dry. dont' wipe off. close your hood and drive it or let it run and you'll be amazed. here's my engine bay, it's a not a good picture, but it's all i could find.
http://www.jdmhondaparts.com/g...1.htm
Old Jun 7, 2003 | 02:11 AM
ophdehEEzY
Guest
Posts: n/a
Default Re: engine cleaning (ISELLRIGHTHANDDRIVES)
my POS
Old Jun 7, 2003 | 12:24 PM
koco's Avatar
-WOW
Motor looks clean.
The ignition wires should not be crossed like that. It's possible for current to be inducted into the other wires. You should follow the original factory routing for the wires.
Old Jun 7, 2003 | 12:29 PM
Default Re: engine cleaning (koco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koco &raquo;</TD></TR><TR><TD CLASS="quote">
Motor looks clean.
The ignition wires should not be crossed like that. It's possible for current to be inducted into the other wires. You should follow the original factory routing for the wires.</TD></TR></TABLE>
thanks! and to be honest....i didn't even realize i crossed them...must have done it when i changed the plugs
EDIT: wires now corrected
robcivic559
Sep 19, 2009 07:12 PM
drumminforev
15
Aug 17, 2006 11:59 PM
tanklee
Apr 11, 2006 08:51 PM
nickolas388
Oct 16, 2005 08:12 AM
Standard One
Feb 8, 2004 01:02 PM
