engine cannot be cleaned!!
Old Sep 23, 2002 | 09:57 PM
ILOVEGIRLS's Avatar
Default engine cannot be cleaned!!
ok..ive used simple green and the castrol degreaser..engine cleaner. i just got my motor back and it didnt look that shiny like i thought i was going to be so i tried cleaning but it seems to be stained somehow. do u guy know anything else i can use to clean it? id rather much clean it than paint it aluminum. btw..this motor is sitting in my garage so hard corners and stuff are not an issue.
Old Sep 23, 2002 | 11:20 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: engine cannot be cleaned!! (ILOVEGIRLS)
post pics so we can see exactly what it looks like
Old Sep 24, 2002 | 12:03 AM
Mr. Thunderlips's Avatar
Time to break out the rattle-cans. It was the only solution for my old ZC. Re-sprayed the block and intake manifold...And later the valve cover. I can't even describe the night and day difference. All of a sudden you then realize that little things like the dirty A/C condenser...
[Modified by ThunderLips, 1:04 AM 9/24/2002]
Old Sep 24, 2002 | 07:05 PM
ILOVEGIRLS's Avatar
Default Re: engine cannot be cleaned!! (ThunderLips)
o man..what kind of paint did u use? has it ever flaked? ive heard that if later on i spray it with simple green the paint will come off.
i dont have any pics..ill try to get some up though
Old Sep 24, 2002 | 08:52 PM
High heat engine block paint...They also have a similar paint for intake manifolds...Every auto parts store carries it. Never had any problems with the paint coming off...Just don't hold a super high pressure blaster 4 inches away from the painted surface.
Old Sep 26, 2002 | 06:56 PM
ILOVEGIRLS's Avatar
thanks. i may have to do this if its my last resort.
Old Sep 30, 2002 | 05:38 PM
ILOVEGIRLS's Avatar
Default Re: engine cannot be cleaned!! (chrisonepointsix)
ok..im gonna paint this sucker..btw. does the ref cae if its painted? thanks.
Old Sep 30, 2002 | 08:57 PM
As far as I know, paint will not affect anyhting whatsoever.
Old Sep 30, 2002 | 09:52 PM
MistaKilla's Avatar
you should use a 3500 psi pressure washer. I use that and it cleans my motor to perfection. Then I put max 2001 on the hoses. *note - The motor should be running, if you are planning to use the motor within 2-5 days.*
Old Oct 1, 2002 | 06:43 AM
integranator's Avatar
Default Re: engine cannot be cleaned!! (MistaKilla)
If you have the time, and the money, you could take it to be hot tanked by a machinist shop.
Old Oct 1, 2002 | 06:28 PM
ILOVEGIRLS's Avatar
Default Re: engine cannot be cleaned!! (integranator)
it was hot tanked but the freaking thing looks like it has underwater stains some how. anyhow..i painted it..but the freakin thing came out like a JG painted motor. the cap was a dull grey..but when it came out..it came out all shiny.
Old Oct 1, 2002 | 09:47 PM
It will most likely get slightly dull after some warm up and cooling down sessions...Don't fret.
Old Oct 2, 2002 | 01:41 PM
ILOVEGIRLS's Avatar
thats good to hear.
JUN.
Apr 12, 2006 08:00 PM
d16dcoe45
Aug 22, 2005 04:31 AM
firstgenrex
23
Oct 9, 2003 02:01 PM
dingusjt
11
Aug 11, 2003 12:20 PM
boosted3g
Nov 9, 2002 03:53 PM
