Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Accord 5 speed wont go into gear / Clutch issue?
Old 01-31-2020, 03:49 PM
-16V-'s Avatar
Default 2007 Accord 5 speed wont go into gear / Clutch issue?
Hey guys just got done driving my car and was noticing while changing gears it seemed like it was harder and harder to go into gears while shifting. So i made into my drive way and now my car wont go into gear while car is on and pushing in the clutch pedal. The clutch pedal does feel a lil weird and has a lil bit of pressure. Goes into gears when car is off and without using clutch pedal. Didnt see any fluid leaking from clutch master or slave. Had my wife get in the car and press the clutch pedal and it looked like the slave push rod would barley move. How far should it travel ?
Im thinking that my clutch master has some type internal failure. I just dont want to start throwing a bunch of parts at it. Anyone have any similar issues?
Old 02-03-2020, 11:43 AM
-16V-'s Avatar
Default Re: 2007 Accord 5 speed wont go into gear / Clutch issue?
Well did some troubleshooting and found out i have a broken clutch pedal, and after some more researching its very common with some 7th gen accords.
Old 02-14-2020, 05:15 AM
Hawkman54's Avatar
Our clutch issue turned out to be the clutch slave itself. Once we replaced it, all that was needed was adjusting. Good luck.
Always262
Transmission & Drivetrain
06-25-2017 07:16 PM
favd21
09-08-2012 03:00 PM
Juans_MX3
11-11-2011 04:51 PM
91SI92
04-23-2011 11:44 PM
codybb4
12-09-2008 08:44 AM
Quick Reply: 2007 Accord 5 speed wont go into gear / Clutch issue?
