white smoke after gasket change
i have a 2003 v6 honda accord and i just did a full overhaul on the engine due to a fail head gasket..the head gasket was blown due to a block catalytic converter and now that the gasket was replace my car still blows white smoke..i have driven it for 5 miles so far
Re: white smoke after gasket change
the heads was taken to a machine shop and didn know if the mechanic check the cylinder walls but i was told to drive it for a while to take out water that was left in engine
Um, who told you that!?! There shouldn't be ANY water in your engine. Did you change the oil and filter?
when you blew the head gasket some oil may have been leaking into the cylinder for the last short while you were driving the car even for just a few miles and oil and water may have gotten into your exhaust pipe so you may just be having some burn off from the pipe itself continue to drive the car for another 20 miles or so and if its still smoking check for loss oil or water
It's possible you're burning off moisture in the exhaust system, but that wouldn't have continued for five miles unless water is continuing to leak into one or more cylinders.
Were it my car, I'd pull each plug in sequence, pressurize each cylinder and look for bubbles in the radiator.
thanks guys for responding.....i check the coolant level and there is not even a slight sign of leakage and a full service was done on the car even the coolant was flush and change
youngkow
12-27-2003 12:18 PM
hybridtech
05-13-2003 02:47 PM
