changed head gasket, white smoke, oil in all four cylinders, How do you check pision rings?
changed head gasket, white smoke, oil in all four cylinders, How do you check piston rings?
A few weeks ago I was driving and my car lost alot of power and white smoke shot out the exhaust. I pulled the head off and changed the gasket. The number three cylinder had a piece of gasket in it and bumps on the piston and a couple of valves. I think some of the head gasket melted to them. The gasket was stretched like the head lifted or something. I didnt notice any cracks in the cylinders, put the new gasket on. I started it up and alot of white smoke shot out so I drove it around thinking that maybe it was from left over coolant, but it only got worse and the car felt real weak. I checked the plugs and there was oil on all four plugs, there is also white smoke coming from the BOV. As it was running I pulled each spark plug wire out and checked to see if the engine bogged down. The number three cylinder did do anything and I am getting spark from the plug. I guess it it getting flooded with oil that it isnt sparking.
Is there a way to check the piston rings? I read on another forum that you can tell by doing a dry and wet compression test. Whats a wet compression test and what do I look for to tell?
Whats the torque specs for the head bolts on a zc motor? (I torqued it to 61)
What else could it be? I dont have a compression guage yet.
Thanks for any help or suggestions
Re: changed head gasket, white smoke, oil in all four cylinders, How do you check piston rings? (hyb
do a leak down test that can tell if the rings are leaking or not
I dont have a compressor or a leakdown tester thingy is there anything else that I can do to test it?
you local to the DFW area i can come check it out for you i have both those guages do you have air compressor available at your locations
1 Post
a dry comp teset is a regular comp test. Do that first. When you find which cylinder seems low, pour a cap full of oil into the spark plug hole (wet comp test). Redo the comp test, and if the numbers are fixed from the oil , its the rings.
Since you blew the headgasket, i am sure you messed up the surface of the head. When blowing headgaskets, dont simpy just throw on a new one. Take the head off again, get a precision straight edge and check for warpage with feeler gauges.
Most likely your going to have to remill the head.
Hey b18bturbo, I live in Arlington but the car is in Springtown its about 60 miles from Dallas.
If the head is warped wouldnt I be getting coolant with oil in the cylinders?
But I'm also getting oil in all four, I dont think the rings in all four cylinders would go bad.
Modified by hybridtech at 9:13 PM 5/13/2003
JunkyardAccord
11-18-2008 10:11 AM
gray_civic_coupe
01-16-2006 03:15 AM
