Question on rims fitting...
I have a 2003 accord coupe V6 AT, I need to know if 18" rims with 245 tires will fit.. or if they'll rub.. if anyone knows or if they have tried in the past.. whatever.. I just need to know if they'll fit/rub... thanks!!!
Re: Question on rims fitting...
OP- It may help if you post your full wheel/tires specs (i.e. wheel width, offset, tire specs, etc.) to better analyze whether the tire combo may rub.... just a suggestion By the way, I've seen some 7th Gen. accords running the following specs:
18x8et45 TL/TSX ASPEC wheels with 245/45/18 tires
17x8et45 TL/TL-S wheels with 245/45/17 tires.
I hope this helps . GL with your search and wheel combo!!
I have a 2006 accord...I just put 235's on it(evolution lancer rims) and they rub very little when cut all the way and backing up....But nothing major! you should be golden!
jond
16
03-08-2005 09:12 AM
