K24 Accord vs K24 TSX
This topic maybe has been brought up before. Can any one tell me or lead me in the right direction to find out the difference between these two.
Re: K24 Accord vs K24 TSX (edulerp97)
hope this helps.. theres a smal difference if ur talking about engines, the tsx is now pushing 205hp and the accord 190hp , torque is about the same , the olde models of accord 06-07 166hp, 03-05 160hp, tsx 04-06 200hp, 07-08 205hp if im not mistaken, both are 4clyinders and has 16-Valve, DOHC, i-VTEC, price on each is different , swaps a accord 2.4 would run as low as 2,000 not including labor and a tsx would run close to 5,000 not including labor, cars themselves as wholes .
accord 22,000-25,000 4cylinder and tsx 28,000-30,000, also accord is a 5sp and tsx comes with a 6spd still 4cly........
um... k24 on accord 03-07 is different than 03-08 tsx, tsx is real vtec, accord doesnt hence the 40hp difference. the k24 for the 08+ accord is completely different engine design so they cannot be compared where as the previous models was only major differences were the head and cams.
Re: K24 Accord vs K24 TSX (K24power07)
I have a k24 accord and my roomate has the tsx 6 speed and we have been planning on running them so ill post the results. otherwise the tsx is a bit shorter wheel base than the accord sedan.
It really just depends on what style you like and what you get a badass deal on.
Re: K24 Accord vs K24 TSX (MantiSWhite)
the tsx is gonna whip you, your accord is 160 with 5speed, tsx is 200 with 6 speeds...but then again its the driver, the accord can keep up but the tsx will win. it all depends on the driver though.
billk1002
11-21-2014 10:52 AM
