Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
High pressure PS line flare nut rounded, need help
Old 12-28-2011, 04:22 PM
astr627's Avatar
Default High pressure PS line flare nut rounded, need help
I was trying to replace the PS high pressure line on my 2004 Accord V6, but I accidentally rounded the flare nut even that I was using a 14mm line wrench.
Now I'm stuck and really don't know how to get the flare nut off. I googled a little bit and people recommend PB blaster penetrant and mini vice-grip (the clearance is really small), so I'm wondering if this the best way to do it. Please let me know if you guys have other ideas, thanks a lot!
Old 12-28-2011, 05:17 PM
exb18c1's Avatar
Default Re: High pressure PS line flare nut rounded, need help
Cut the line flush with nut and wack a socket on it ,then use the rachet.
Old 12-28-2011, 05:24 PM
astr627's Avatar
It's a metal line and the clearance is small, what kind of tool you suggest to cut it?
Old 12-28-2011, 05:34 PM
exb18c1's Avatar
If you are at home conditions ,I would think about Dremel with cutoff disk.Wear the goggles!!!Or if you have a long sharp chiesel and hammer ,it would work too.
Old 12-28-2011, 08:27 PM
My Name is Nobody
MSchu's Avatar
vice grips have almost never failed for me in that emergency situation. get that fugger on there as tight as possible, it will come off.
Old 12-29-2011, 08:39 AM
astr627's Avatar
I just got the vice grip, will try it later.
inane
04-04-2005 07:15 PM
jsnm
03-03-2005 01:29 PM
Louie_EM1
12
02-27-2005 11:16 AM
Quick Reply: High pressure PS line flare nut rounded, need help
