HELP! - 2009 Honda Accord "Engine Malfunction Indicator"
So 2 weeks ago from this post, my radiator was damaged. I got it fixed and picked it up from the mechanic on Tuesday (1/18). The day after (1/19) my coolant gauge needle had gone past H in which my engine started to overheat. I happened to make it home from where I was, but I had to stop multiple times to let the engine cool. It so happens that the radiator tube fueling coolant had popped off so I was basically destroying my engine. I took it to the mechanic today and he put the hose back on and changed my oil since the oil was a bit burnt. However, when the engine is off and I turn the key to where all the lights are shown, the engine malfunction light stays on the screen, blinks a bit then goes away. When I start the car up, the light goes away. Should I take it to the dealer to get it checked out? If I do, how much will it cost to have them check it and how long will it take? But I also heard something about the light turning off on it's own? I'm getting extremely frustrated with all these stupid car problems, I would greatly appreciate it if someone could help me out.
Re: HELP! - 2009 Honda Accord "Engine Malfunction Indicator"
Like GoLowDrew said, the engine is just checking its self. Also if you have a Auto. transmission when you first turn the car on the P light will be on, but at the same the the D light should stay lit for 5-10 seconds. The transmission is checking its self.
Jane Morris
11-27-2016 09:24 AM
GLlee90298
11-29-2008 12:22 AM
slaint
07-11-2004 08:52 PM
