Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Engine whine [VIDEO]
Old 07-21-2015, 11:26 AM
brian0918's Avatar
Icon2 Engine whine [VIDEO]
On my 2006 Accord V6, the engine just started making a whining noise that increases in pitch as I push the gas pedal. The whine occurs even with all accessories off, with the radiator fans off, and no matter what gear I am in.
The whine seems to be coming from around the serpentine belt area. I replaced the belt sometime last year, so it should still be in good shape.
You can hear in this video at the beginning the fans turn off, and then I increase the RPM.
Any ideas?
Old 07-21-2015, 11:41 AM
brian0918's Avatar
Default Re: Engine whine [VIDEO]
I see in another thread someone recommended removing the serpentine belt. Is there a fuse or something I could unplug that would have the same effect, to stop that belt from turning?
Old 07-21-2015, 05:16 PM
BLKFLSH's Avatar
The power steering pump is not electrical. If you don't want to remove the belt, simply change the inlet joint o-ring. The o-ring doesn't cost much, and it's the most common cause for the noise.
Old 07-24-2015, 02:26 PM
Lost Again's Avatar
Yes, it could be the PS pump/line o-ring, that usually only shows up when the car is cold.
Does this noise happen all the time - cold engine and when the engine is at normal op temp? You talk about the fans but I don't kow if they are running because the ac is on.
Any recent work done to the car?
strinm02
05-05-2014 06:47 AM
MrsR
16
08-24-2013 06:37 AM
BPA
05-06-2013 11:32 AM
back2boostin
Honda Civic (2001 - 2005)
03-13-2011 10:02 AM
JLange
08-27-2002 06:11 AM
Quick Reply: Engine whine [VIDEO]
