Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Clutch not engaging when engine is running
Old 03-27-2018, 03:24 PM
JDTrenta's Avatar
Default Clutch not engaging when engine is running
I have an '06 Accord, 4-cylinder with just under 150k miles. Recently I've noticed difficulty in shifting gears when the engine is running (no trouble at all when car is off). From what I'm reading it's likely a worn our clutch disk and/or pressure pad - does this sound reasonable? Also, when I called a couple mechanics they tried to tell me it was a multi-day repair and required additional work to fluid systems in addition to the disk and pad (aka $2k+ labor) which seems excessive.
Any advice?
Old 03-28-2018, 01:30 PM
94 accord typeR's Avatar
Default Re: Clutch not engaging when engine is running
Look on youtube for clutch repairs or transmission repairs in general. If you think u can do it yourself go for it. If not shop around transmissions are the same basically anyone and remove/install. Be prepared for rusty bolts etc
B20bB16a
06-28-2017 12:46 PM
japan_ease
10-13-2008 09:01 AM
dtddan
02-14-2007 02:23 AM
IN VTEC
12-09-2006 07:29 PM
Quick Reply: Clutch not engaging when engine is running
