Clutch
Re: Clutch
My advise, spend 22~27 dollars on a service manual from www "automanualsource" (dot) com
Then take your time and do it right...new flywheel, take care of/inspect the rear main seal....ect.
Re: Clutch
Transmission is going to come out the bottom. You will need to drain the transmission gear oil, remove axles, mounts, clutch cable, wiring, and place a jack under the engine. You will need to tilt the whole assembly downward which will allow you to remove the transmission. As someone mentioned above purchasing a shop manual wouldnt be a bad idea, its good to use as a reference down the road anyways. Otherwise you can search online for the directions.
Re: Clutch
As others said, the transmission comes out of the bottom. There is no need to pull the motor to do a clutch on these cars. Just have something like an engine hoist holding the motor from the top.
mechmunkee3
02-15-2008 02:24 AM
