2007 accord dome light
Hey guys. I am new to this forum. I started driving today and looked up and both the front and rear dome lights were on. No door was open or trunk. I went through each door and opened and closed. The front one is a 2 switch door or off. It doesn't matter which one it is in the lights stay on. Even if I turn the car off, they still say on. Any idea what this could be. I live in Phoenix and it has been very hot and the car sat outside the last 4 days.
Thanks
Thanks
Re: 2007 accord dome light
look at your door jamb switches. I have found a lot of times there is a small dent in one of the doors right where the door is suppose to hit the door jamb switch. Check for any dents in your doors, if you find one all you have to do is find some foam that is sticky on one side and apply the foam pad where the dent is and the foam provides enough thickness to properly close the door jamb switch. close all of your doors and open one at a time and push the door jamb switch with your finger for about 10 seconds and see if your light goes off.
good luck bud.
good luck bud.
wraydp
29
05-13-2017 03:44 AM
