2006 Honda Accord V6 Evap Leak
Hi all: I've been having water on the passenger side carpet in my '06 Accord V6. I pulled the front passenger carpet back and pulled the drain hose out and was going to blow it out when I noticed that the water was dripping from behind the dash, above the hose. The hose goes into a black plastic case, and the leak is at the bottom of the black case. See the attached image, which is taken from the passenger side and viewing behind the center dash. You can see the black drain hose and I've circled the dripping water in red.
Does anyone have any thoughts on this? Thanks in advance...
Cas8100
Cas8100
Re: 2006 Honda Accord V6 Evap Leak
Clear the hose and see if that slows/stops the water. If you can get to the "other" end of the hose from under the car, a shop vac on "wet" will clear/pull most of it out. You want to be careful not to get too much water on the "controller" to the left in your pic.
The hose seems clear and it does drain onto the garage floor. Ill give the suction a shot and see if it helps get anything higher up. Thanks for the response and also for the warning on the controller.
kevinhughes13
05-10-2014 12:28 AM
oddlaww
09-25-2008 06:54 AM
nramil
07-23-2008 08:41 PM
