2005 honda Accord 2.4l motor starter bolt
My lower, thicker and shorter motor starter bolt (17mm head) broke inside the engine block while trying to unbolt it to replace the starter.
Now, besides the fact that I will need to extract the bolt, I also need a new one. Can someone tell me what are the exact dimensions of the bolt or the part number?
Re: 2005 honda Accord 2.4l motor starter bolt
I couldn't extract it at all. I ended up drilling through it and then tapped it to the next bolt size. I think I used 1/2" bolt with coarse thread.
Not the most fun thing to do, but it worked out in the end.
Hi, Im sorry you had to go through all that but glad you got it going. I recently discovered i need to replace my starter as well. It sometimes turns over after many cranks. Sounds weak/slow tyrning over. Sometimes just a click, sometimes nothing. Best results when i have all the electronics off( radio, ac, lights, etc..). Took to orielys and was told bad battery. After wire brushing all connections, and replacing battery same ol s***. Took back now it says bad starter. I removed negative cable from battery post and it died. So now im at replacing the starter.My question is, how common is it to break that 17mm bolt? Ive read quite a few posts about that same bolt breaking while replacing the starter. Im not talking **** by any means but did you by chance cross thread it and kept going? I know the bolt is going into an alluminum body, maybe the threads gaulded and the bolt siezed? Spraying kroil or wd40 wouldnt mess with the electrial system in the starter any way right? Not bathing the entire starter in it, just the head of the bolt?Again, that sux u went through all that and im not questioning your skills as a mechanic, just asking. Tryna avoid that situation if at all possible! Thanks,Daniel
Sherryl
08-27-2018 07:29 AM
