2005 Accord V6 no start issue.
Battery is brand new, has power to the car but when try to start it doesnt do anything. Pulled the starter and had it tested and it works. Checked battery to starter cable and theres power to the starter. Seems like its not getting signal to try to spin the starter.. Im all out of ideas. Im almost thinking this could be a problem with the immobilizer or something like that?
Re: 2005 Accord V6 no start issue.
Is your car an automatic or manual transmission? If it's a manual trans, is the clutch switch plug in the clutch pedal arm? Sometimes they'll pop out and won't allow the switch to close and ground the starter relay. Do you have battery voltage on the small black/white wire going to the starter pull in windings? Make sure the connection is good there. You've probably already checked this, but are the battery connections tight and clean? Check the simple things first.
street_ride14
08-25-2014 05:20 PM
