Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2005 Accord EX Starting issue
Old 09-14-2015, 07:41 AM
bkemp103's Avatar
Default 2005 Accord EX Starting issue
Hey, I have been here for a while but not active. I had a starting issue with my 'ol reliable and at first, I took it to Meineke in Atlanta and was diagnosed with a bad fuel pump. They replaced the pump, filter and plugs but told me i needed a new ignition because the car kept trying to cut off and it was the ignition which burned up the pump to begin with.
Welp, after the new ignition, I drove the car home and in the morning it would not start. (good thing it is a 5 speed). I drive from Atlanta to Vicksburg maybe twice a month. When I go to Mississippi, a mechanic told me to check the clutch switch, which I changed. (Nothing). The I was told the solenoid on the starter was bad, had starter rebuilt. (Nothing). Another mechanic told me that changing a Honda starter without 'flashing' messes up the computer. At this poin, I am ready to take 'ol Reliable to a Honda Service Center.
Anybody have this issue before? any suggestions which have not been covered already?
Old 09-15-2015, 02:36 PM
poorman212's Avatar
Default Re: 2005 Accord EX Starting issue
What is happening when you try to start the car?
Does the starter spin the engine or nothing?
Old 09-21-2015, 02:01 AM
bkemp103's Avatar
The lights come on, as normal, but the engine does not try to turn over, like no voltage is getting to the starter. I have to pop the clutch to get it started.
Old 09-21-2015, 03:03 AM
poorman212's Avatar
Well that is the next thing I would check - are you getting voltage to the small wire on the starter when someone tries to start the car.
Blaze45
11-29-2017 12:07 PM
Nick Effler
05-19-2015 10:06 AM
Matt2000EX
11-02-2010 11:31 PM
stamen
10-10-2007 08:31 PM
1986CRX
02-19-2003 07:36 PM
Quick Reply: 2005 Accord EX Starting issue
