2005 Accord Ex 4dr Manual Clutch Sticking to Floor
I have to push the clutch all the way down to put the car in 1st gear and it seems to stick sometimes to the floor and then I cant push the clutch down again to put it in 2nd gear. I'll have to pull over to the side of the road and manually pull the clutch up with my hand. I basically can hold the clutch in 1st gear ? afterwards when im driving all the other gears are fine.
I have read a lot everywhere am i do not have any fluid leaking into the cabin by the clutch bad. So this is supposed to lead me to believe that it is an internal leak perhaps ? I will have to change my Master Clutch Cylinder and Slave Clutch cylinder ? I am not quite sure... however if it is the case that i have to replace them is there a DIY guide anywhere ? i have seen some here for 2006 acccords and accords older than mine 2005.
Please I am new to this forum and would like to get into the doityourself trade for the up keep of my car.
Hope i dont get flamed for this.
2005 Accord Ex 4dr V4
Re: 2005 Accord Ex 4dr Manual Clutch Sticking to Floor
make sure there are no leaks in the clutch lines if thats not it then your screwed cause your gonna have to take apart the tranny to check internals cause something is on its way out, meaning about to break or go bad.
Zachary Burrows
05-10-2016 02:07 PM
