Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2004 Accord 4cyl - what would be cost to replace timing chain and clutch?
Old 04-15-2014, 07:00 PM
theLemur's Avatar
Default 2004 Accord 4cyl - what would be cost to replace timing chain and clutch?
I'm just wondering what you think an independent shop would charge (parts and labor) to replace my timing chain, as well as my clutch/bearing/pressure plate. My car needs both and I'm not sure if it's worth having it done, or just driving until catastrophe strikes
Old 04-15-2014, 07:07 PM
johnsc2235's Avatar
Default Re: 2004 Accord 4cyl - what would be cost to replace timing chain and clutch?
why does the chain need to be replaced?
Old 04-15-2014, 07:09 PM
theLemur's Avatar
I believe it's stretched from 4 years of low oil levels.
Old 04-15-2014, 08:45 PM
PrettyMuchBoned's Avatar
Clutch should be around 500 plus parts. Timing chain, dunno man. Never done one of em before. You should a trusted mechanic to check that its actually bad before you spend that much money on it.
also, keep up on your oil. Please. And do changes every 3,000-4,000 miles
Old 04-15-2014, 08:50 PM
theLemur's Avatar
I did them religiously at 3000 miles but it would always be 2 quarts low by that time. The exhaust never looked like oil was burning and I could never find oil leaks. It was always a mystery and I just couldn't keep up with adding oil all the time. When the light would come on I would always add some immediately, but it seemed like the light was more of an all out emergency status.
Old 04-15-2014, 08:58 PM
By the sound of it, either you got a car that shouldn't have passed quality control, or the previous owner didnt take as good care of it as you(if you're not the first owner)
I dont trust the oil light either, like you said its probably more of an emergency thing.
perhaps you should consider a secondary oil pressure sensor with a gauge in the cabin?
or just keep a qt in the car and check it sometimes when you buy gasoline. I never used to do it with my V6 accord, but I was driving my dad's old yota pickup and that thing leaks/burns a qt in a week or two lol. After a little while you get pretty used to it. It doesn't waste any time, you're stuck at the station for a little while anyway. They even usually provide paper rags for this purpose.
Old 04-15-2014, 09:04 PM
theLemur's Avatar
I got it 4 years ago at 104k miles (177k now) and it was looking pretty good. I do shift at redline like 20x every time I drive it I've learned to keep spare quarts in the trunk. The car doesn't run good since the timing is slightly off, and it throws a code for camshaft position. (I think i'll cover that up with some black tape). I can feel and hear the sound of the timing being off, unless i'm just cruising down the highway. Plus the mpg is way down..
I think I'll just drive it until it explodes. I got it for next to nothing, and I can't get a title for it (long story) and fixing everything would be too big of a risk. When it explodes i'll sell it for parts and buy another and repeat.
Old 04-15-2014, 09:08 PM
What color is it? I'd love to have a graphite pearl parts car. I need a hood/fender/rear driver door/trunk. That I know would fit.
I also need a driver side front wishbone, subframe, prolly some other stuff too. Dunno if the v6 shares these parts with the I4 too
Old 04-15-2014, 09:09 PM
Also is it 2 or 4 doors? I dont think all of the coupe parts fit lol
Old 04-15-2014, 09:13 PM
theLemur's Avatar
It's a sedan and it's a dark blue. Most panels have small dents or scratches since I usually push shopping carts out of the way and nudge small children.
Old 04-15-2014, 09:35 PM
I do the same **** lol. Except mine got ran over by a lifted truck and I kick flipped it over a retaining wall, thru a mail box and ended up backed into a driveway. Never mind then, thanks anyway though.
Old 04-16-2014, 06:30 AM
theLemur's Avatar
Good lord, I'd say you have me beat there..
condor22
01-01-2015 08:03 PM
live4soccer7
40
09-21-2011 02:54 PM
r3000
05-14-2005 06:47 AM
NoSpeed
10-23-2003 05:10 PM
Quick Reply: 2004 Accord 4cyl - what would be cost to replace timing chain and clutch?
