2003 - 2007 K24 Accord Auto Transmission Fluid & Filter ?'s
I'm in the process of changing out the Transmission fluid on my 2003 Honda Accord EX Automatic. It is the 4 banger K24, incase you missed that in the title. I would like some clarification prior to starting the process.
1. How many quarts of Honda ATF-Z1 will I need for a drain & fill?
2. Does the K24 Auto have a serviceable transmission filter? If so, where is it located?
3. I will be doing 3 drain & fills within the next 1,000 miles, since I've neglected it in the past. Is there anything else that you would reccomend I do?
4. Is there anywhere I can get Honda ATF-Z1 for cheaper, since I will be purchasing a large quantity of it?
Thank you for taking the time to read my post. Happy Holidays!!!
Re: 2003 - 2007 K24 Accord Auto Transmission Fluid & Filter ?'s
1. 2.8-3.3qts
2. no filter just drain and refill
3. each time u drain and refill just run it thru all gears
4. only place to get honda atf is thru honda..maybe u can find it cheaper online
just make sure after ur last drain to change out the tranny drain plug washer so it doesnt leak
be professional
1. 2.8-3.3qts
1. 2.8-3.3qts
2. No filter just drain and refill
3. Each time u drain and refill just run it thru all gears
4. Only place to get honda atf is thru honda..maybe u can find it cheaper online
couldnt say it any better.
I did find that the 03-07 Accord's have external transmission filters. The part number for them is 25430-PLR-003. Any thoughts on this?
be professional
They're about $20 from Honda. There is no service interval specification for them that I am aware of.
i just asked one of our master techs and he said honda started putting those inline filters on starting in 05 and no there is no service interval for them
Now I just need to find somewhere that sells Honda ATF for less than $8.00/qt, if it even still exists. I need two cases.
www.nike-air-shoes.com
We wholesale brand sneakers,Cheap nike shoes,discount Air Jordans,Air Jordan I II III IV V VI VII VIII IX X XI XII XIII XIV XV XVI XVII XVIII XIX XX XXI XXII XXIII shoes,new Mix jordan shoes,Women?s air jordan shoes,Air max 87 88 89 90 91 95 97 360 2003 2009 TN LTD shoes,Nike shox R2 R3 R5 NZ TZ TL1 TL3 R4 shoes, Nike dunk shoes, SB Dunk shoes,Nike air force 1 shoes,Air force one 25th shoes,Nike kid?s shoes,Kid?s jordan shoes,Adidas shoes,Adicolor shoes,Puma shoes,Gucci shoes,Basketball shoes,Prada shoes,ATO shoes,Bape star shoes,D&G shoes,UGG boots,Timberland shoes,supra shoes,Other brand boots(Women?s),and Wholesale cheap brand clothing,cheap Coat,Hoody,Jeans,Sweat,Suit,T-shirt,Long-sleeved T shirt.Cheap brand Handbags,AAA bags,Purse.Cheap Rolex Watchs,Cheap brand belts,Brand hats,Brand scarf,Brand sunglasses. www.nike-air-shoes.com, all of the discount brand of goods from China
Email:nikeairshoes0@gmail.com MSN:nike-air-shoes@hotmail.com
Yahoo message: nikeairshoes0@yahoo.com
be professional
In anycase, I sucked it up, and pick'd up 4qts of Honda ATF Z1 last night at the local stealership @ $8.02/qt. I did a quick drain and fill, and I must say, that stuff was pretty much black in color. I plan on doing another drain and fill in 500 miles, and the third one in 1,000 miles from now. I will replace the filter on the 4th and final drain and fill in 2,000 miles. From there, Ill keep doing them in 15k mi increments.
Automatic filter(s) and fluid change question
I recently purchased a 99 Accord EX Coupe with a slippin tranny. Before I breakdown and buy or consider converting it to a 5speed, is it possible for me to (DIY) service the automatic tranny. This past weekend, I purchased some Valvoline over 75k mileage transmission fluid and a bottle of Lucas Transmission Additive. I would like to change the any all serviceable filters also. I believe that the tranny should be treated like an engine; if you change the oil change the filter. Also, have any of you DIYers tried a transmission flush job along with changing the fluids, filter(s)????
be professional
2. You should only be using Honda ATF-Z1 fluid.
3. Don't use additives. Waste of money. Especially any crap made by Lucas Oil.
4. You're not going to prolong the life of an already-slipping transmission by flushing it; if anything, you'll only accelerate failure. Return the fluids, get your money back, and put it toward a good used transmission, or a Honda remanufactured transmission. Don't go to any chain or local transmission specialty shops that advertise or quote a low initial price to get you in the door (i.e. $1000-1200); you'll end up spending a lot more in the long run. Do it right the first time and buy a Honda remanufactured transmission for $2300 with a 36 month/36,000 mile warranty.
Targa250R,
I'm really feeling as if automatic trannys' are nothing by ticking time bombs; it's only a matter of time before they cost the owner eveything.... What about simply converting it to an 5speed??? It seems as if for the amount for a automatic tranny, a owner mightest well, convert it to a 5speed manual... I can't see spending $2300 for a tranny, and I bought the car for less... Automatic trannys' is the worst inventions for cars; yes/no...
be professional
With that said, '98-02 Accord automatics (both 4-cylinder and V6) are exceptionally well known for transmission problems, much moreso than the previous and following generations. Honda did extend the transmission warranty on some models, but the '99 model year is no longer covered.
A manual conversion would indeed be cheaper than a remanufactured transmission, but it involves quite a lot of details. You may want to try to source a good used automatic trans (or at least get an idea of pricing) before you make any decisions.
This is an old thread, I know. But I am new here.
My '03 Accord 2.4L w/ automatic transmission is seems to be leaking transmission fluid. The engine leaks oil, too. The trans is wet on the bottom w/trans fluid.
Any thoughts appreciated.
13 year old car may need seals and gaskets, maybe more, but, don't pour in stop leak.
bigcc63
12-13-2017 10:14 PM
Salty2000
03-27-2014 12:29 PM
talan41
10-23-2008 06:25 PM
maxmk8
04-21-2008 10:32 AM
aktam
11
11-27-2007 05:38 PM
