Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
'05 Accord Coupe LX power power outlet failure
Old 12-13-2012, 05:37 PM
user114's Avatar
Icon6 '05 Accord Coupe LX power power outlet failure
I noticed the other day when I went to plug in my phone charger is wasn't working. This is the power outlet near the shifter. I have already checked the fuse and it was intact. I there another fuse somewhere else? Perhaps in-line?
Much advice needed.
Old 01-24-2013, 04:07 PM
LadyAntler's Avatar
Default Re: '05 Accord Coupe LX power power outlet failure
I am having the same problem. No power to the Power Point Plug. I can't charge my phone either. I checked the fuses and they are fine. Any suggestions on what to try next?
Old 02-04-2013, 08:44 AM
bladi3990's Avatar
check the side tap to see if they have tension. Also, place a positive DMM lead on the side and thw negative in the bottom tou should see 12 volts.
Posted from Honda-tech.com App for Android
Old 02-06-2013, 10:58 AM
user114's Avatar
Do you mind re-stating that in plane english for us dunces?
Old 02-06-2013, 04:17 PM
KWayRacing's Avatar
Did you check both fuses for the accessory outlets? Fuse #32 and Fuse #9 both of which are in the drivers under dash fuse box.
hondaown247
Honda Civic (2006 - 2015)
05-07-2015 01:53 PM
Outlaw-Hondaz
09-29-2010 10:43 PM
sneaks
08-09-2010 06:01 AM
wildzx
10
01-08-2010 07:28 PM
idumpwitmy12gaugepump
Audio / Security / Video
05-22-2008 07:18 PM
Quick Reply: '05 Accord Coupe LX power power outlet failure
