05 V6 misfire
05 V6 misfire
I posted awhile ago about some engine codes, which stated that there was a misfire on 3 and 5. So today I finally got around to replacing all 6 plugs hoping it would take care of the issue. During the "test run" the malfunction indicator came back on, so I ran a code reader. This time it said 1 and 5 are mis firing.
My next guess is to mark the coils and through process of elimination, switch them around until the 2 bad ones are isolated. I don't know the firing sequence, so it'll be a total guess.
Is there anything else I should look for? Or any better ways to attempt to diagnose this before heading to a shop and having it hooked up?
Thanks!
Thanks!
Re: 05 V6 misfire
Thanks for the firing order. I was having such a google fail earlier and couldn't find it. That and the dealership service dept was closed at 4.
Re: 05 V6 misfire
I ran a bottle of STP fuel system cleaner through it about a month ago. I'm heading out of town next week, itd be a perfect time to run another bottle through I guess.
Re: 05 V6 misfire
It's not always 3. When I changed the plugs I moved the coils around. So now 1 is missing instead of 3. I'm going to move the two missing coils again and see if it follows them. If not, then I'll take a shot with the software update. When I talked to the dealer before they mentioned it's been a somewhat common problem in my area due to some less than stellar fuel coming in. The tech said if it was a software issue it would be more randomized codes instaed of the same ones. Meh.. Guess we'll see.
Re: 05 V6 misfire
If the issue comes up again I'll take it to the dealer when i get home and have an update ran. But so far so good.
I did run another fuel system cleaner, have been running 89 grade fuel. Not sure if it makes a differencer or not, but the min grade in my town is 83, Honda recomends 87.
That's all I've got for now. Thanks for all the info!
Re: 05 V6 misfire
The service bullitin does update the software for a missfire, The sensor on the crank misinturprits crankshaft fluctuations as a missfire when in face there is no actual missfire, have updated a few Cars out of the VIN range and its fixed it
Flatland2D
12-04-2008 04:37 PM
