Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 Accord will not shift from park...
Old 07-20-2011, 11:13 AM
bks84's Avatar
Default 03 Accord will not shift from park...
I recently bought an 03 as a daily, everything was fine for the first 3 weeks or so of ownership but now, it will not shift from park.
I hear a light click coming from the column area when I press the brake/push the button on the shifter.
When it first happened I of course jumped on google which told me to check the brake lights, make sure cruise functions properly and if they did not to replace the brake switch. So I did, this did not help. My brake lights work fine, cruise works fine and the little green light on in the cluster work (the one that tells ya what gear youre in)
Ive tried finding info for testing the shift interlock system/solenoid but can't find anything (see custom user title).
Any help would be appreciated!
Thanks in advance.
Old 07-20-2011, 01:51 PM
justinsbg's Avatar
Default Re: 03 Accord will not shift from park...
Have you checked fuse 21 (7.5amps) in the under dash fuse/relay box? Fuse 21 also feeds power to the back-up lights and several other things so if the back-up lights work then it should be fine.
Old 07-20-2011, 03:32 PM
bks84's Avatar
I'll check the back up lights here in a bit but, I checked all fuses the day this started and they were all fine.
Old 07-20-2011, 08:10 PM
bks84's Avatar
Reverse lights work, fuse is not blown (double checked)
What else can I do or check or test to narrow this down?
Old 07-21-2011, 05:40 AM
justinsbg's Avatar
Well there are some things you need to check. You need to check your TP sensor voltage on the Red/Black wire. You should have 0.49-0.51 volts with the ign switch in the on position. That's something that you can check fairly easily. Next I would want to know if the "shift lock solenoid" actually works. To do that the easiest way is to remove the console panel around the shift mechanism that has the seat heater switches on it. It is fastened only by some clips so you just have to gently pry it up with a small flat blade screwdriver or something similar. Go to the 2 pin shift lock solenoid connector and make sure you have battery voltage on the Red wire at the 2 pin connector for the solenoid. If you do, with it plugged up, jumper the Solid Blue wire to body ground. If the solenoid clicks and the shifter moves out of Park then we need to look at other parts of the circuit.
Old 07-21-2011, 06:00 AM
bks84's Avatar
Thanks, my multimeter took a dump, so once I pick a new one up I'll check voltages and report back.
I'm guessing if the TPS has more or less than .49-.51v I'll have to replace it?
Old 07-21-2011, 06:45 AM
justinsbg's Avatar
More than likely but let's see what voltage you have and go from there.
Old 07-21-2011, 06:57 AM
bks84's Avatar
Alright, thanks man. I will report back when I get some results! Probably be a day or two.
Old 07-21-2011, 07:38 AM
justinsbg's Avatar
No worries, look forward to hearing back. Blessings.
Old 07-22-2011, 11:16 AM
sandonn's Avatar
I might be no help here, but I'll try my best...
I had the exact same problem a few months ago, and I also have an '03 accord. I don't remember what the part is called though. Maybe brake light switch...?? It's located under your brake pedal. When you push the brake pedal, and you hear that clicking noise, that's the switch being pressed.
Mine was doing it for a while. On the left side of the shifter there's a little plastic piece that comes out with the help of a knife. If you push down on it w/ a screw driver the car then shifts fine from park into gear.
Anyway, after I replaced the switch everything worked fine. Hope this helped...
Old 07-22-2011, 12:03 PM
bks84's Avatar
I tried a new brake light switch when this started.. didn't help. Bypassing the interlock is how we've managed to drive the car.
Old 07-22-2011, 12:11 PM
sandonn's Avatar
Sorry that didn't help.
Here's another symptom I had. My brake lights worked fine when I was in park. But once I pushed in the bypass w/ a screwdriver to get out of park they stopped working.
Wonder if you were to try that would happen...??
Old 07-22-2011, 12:38 PM
bks84's Avatar
Brake lights, tail lights, turn signals, back up lights all work fine.
Old 07-22-2011, 12:41 PM
sandonn's Avatar
Oh well, guess that's it from me then... I'll be interested to see what it finally is.
Good luck!
Old 08-13-2011, 05:48 PM
bks84's Avatar
CEL finally popped up, ran the scanner and came back w/P0122. Checked the TPS it had 0v @ 0% & 4.8v @ 100%. So I got a used TPS to test, calibrated it and had .5@0 & 4.8v@100.
Fixed my issues, sucks that I had to go to the parts store to clear my code though. We're happy now! Lovin' the car!
Old 08-13-2011, 06:16 PM
soon2bdropped's Avatar
glad you figured it out.. good job on the update..
Old 08-14-2011, 01:22 AM
DominicanFlow's Avatar
acc fuse! happens 2 me all the time lol well atleast thts me ! another wai 2 kno its acc fuse is if ur dash board goes off after a couple min its on!
Old 09-19-2011, 06:40 AM
bks84's Avatar
Problems back, I replaced the TPS with a used one from a local shop. Lasted about a month then BAM right back at it again.
So, I guess we're going to save up for a NEW throttle body w/TPS from Honda and install it.
hatchinprogress
10-06-2012 07:01 AM
tabartis
12-21-2011 09:52 AM
bellyboy
Honda Civic (2001 - 2005)
02-17-2007 11:14 PM
gonzojoey
03-17-2006 01:29 PM
b16a2pwr
02-14-2004 02:28 PM
Quick Reply: 03 Accord will not shift from park...
