03 Accord Headlight adjustment????
I took my whole headlight out and I do not see where there is a gear to adjust the low beam. It just has an empty hole. I even tried the other gear that I thought would move the hi beam and that doesn't move anything as well. Any help would be appreciated.
ate my pixel
1 Post
Re: 03 Accord Headlight adjustment???? (alwayshi)
I don't know the 03 inside and out, but there should usually be an extended screw that you can loosen or tighten to move the headlight up/down.
The adjustment for the headlight is going to be connected to the radiator support, not in the headlight itself.
Well! You've got to use a phillipe (+) screw driver make sure it's about 9inch long. Now open up your hood. Right next to the headlights there's a hole it's got ARROW+ and ARROW-. You may require a flashlight if you are adjusting your headlights at night, I preffer at night because it's easier to see your beam on a wall. Speaking of wall, you should park your car facing a wall about 5-10 feet away. when you put the screwdriver in through the whole make sure the knots match with the white **** on the headlight. It will take a while for you to see the difference...
I've done it so many times... but my passenger side light does not match with it's highbeam. There's about 9 degree difference between the lowbeam and the highbeam...
Can you post a pic of this by chance? I couldn't get it to work. I'm only seeing one hole with the geared screw to turn (the one closer to the front on the plastic that has an "A" next to it), and that one isn't really doing anything. I can't find another screw to turn.
Fuster_Cluck
02-24-2007 11:19 AM
mickey513
03-26-2003 08:30 AM
03, 06, 07, 2003, 2005, 2008, accord, adjust, adjuster, adjusting, adjustment, adjustments, headlight, headlights, honda
